Someone please do a better job then me. I did a rough photoshop using paint to put on some 18s. Taken straight off of the 2016 Honda Pilot Baja Pre-Runner.
Will this stock honda center caps fit in this? If so I am buying this!Ended up putting 17" Touren TR74 rims and Nokian Rotiiva A/T tires in 245/65R17. Very happy with the ride driving home (90 minutes) from the dealership today. View attachment 2067
I like this setup a lot! I’ve thought about going with this setup myself. I really want to get some 18s (Maybe even 17s) on the PP. I’ve done some light off roading on service roads and the pot holes vibrate through your spine even at a very low speed.Snowed this weekend but melted fast. Heres a couple more Blizzak 255/60/18 on Ridgeline 18s.
Thanks! Indeed. These wheels look factory on the PP and exude some of the ridgelines ruggedness. I traded a ridgeline for my pp and found the 20s quite jarring. Not to mention the factory continentals are absolute garbage especially in rain and snow. I spend a lot of time in the mountains and even in town the ruts get pretty crazy in the winter. It’s night and day how much better it rides, especially going up to 255/60/18. These will stay on my car half the year and I’ll probably find another set to put AT tires on for summer. Hell even a set with factory ridge tires would be good. They are much better than the pp ones.I like this setup a lot! I’ve thought about going with this setup myself. I really want to get some 18s (Maybe even 17s) on the PP. I’ve done some light off roading on service roads and the pot holes vibrate through your spine even at a very low speed.
Those look awesome. Did you get a new tire load rating sticker with them? If so would you mind giving the 10 digit number on the extreme right side? I need it to have my Passport’s computer programmed to the“new pull off” Black Edition Ridgeline wheels I bought. According to a master tech and the service manager they need that code to program in vs merely changing the tire size by picking the new size tires. Neither of them had seen computer ask for a wheel code before. I had them scratching their heads when I left this evening. Thank you very much! I’m including a photo of a sticker I found for 20” OE wheels.View attachment 2715
Tire size is 245-60-18. This size tire + 18" wheel = same overall diameter as original tires + 20" wheels.
Couldn't you just get the # off a RL or Pilot (EX-L and below).Did you get a new tire load rating sticker with them? If so would you mind giving the 10 digit number on the extreme right side? I need it to have my Passport’s computer programmed to the“new pull off” Black Edition Ridgeline wheels I bought. According to a master tech and the service manager they need that code to program in vs merely changing the tire size by picking the new size tires. Neither of them had seen computer ask for a wheel code before. I had them scratching their heads when I left this evening. Thank you very much! I’m including a photo of a sticker I found for 20” OE wheels.
I ordered a 2' Lift and am looking to keep my 20" wheels. anyone know what size tires i can run without any cutting or trimming?
Thanks in advance!
Use the Tire Size Calculator? It provides a good estimate for comparing tire & wheel sizes.What changes in the speedometer has anyone had that switched to 245/60R18 tires?
I'm doing the same thing.Looking at the Nitto Ridge Grapplers in 265/60R18 for the summer. 30.5 inch tires. But I've got the Truxxx levelling kit.
Im running 255/60/18 on ridgeline rims on my EXL. Speedo is a little off but not enough to bother with and I don’t know why everyone is so OCD about load calculators and stickers. If they dont rub it doesnt really matter. Any 18-20” light truck tire can handle the PP’s weight just fine.What changes in the speedometer has anyone had that switched to 245/60R18 tires? Any replies please state your Passport trim level. I went with 2019 Ridgeline Black Edition wheels and Falken Wildpeak AT Trail tires that are listed as 29.7” tires and my speedometer reads more than actual speed measured by GPS. With a larger diameter tire it should be slightly higher than the speedometer states. The only thing I can figure out is that the Falken tires are actually smaller than the stated diameter, Falken and Tirerack lists them at 714 revolutions per mile. I’m still in my 30 day trail period and plan on getting Michelin Defender LTX or Continental AT Terrain Contact in 245/60R18, which are listed on mfr websites as 29.6” diameter and 703 revolutions per mile for the Michelins and 702 for the Continentals. FYI the stock tires on the Elite are listed at 29.4”/ 707 RP mile and Sport and EX-L stock tires are 29.7”/ 699 per Continental.
Keep me posted on how that works.Looking at the Nitto Ridge Grapplers in 265/60R18 for the summer. 30.5 inch tires. But I've got the Truxxx levelling kit.
Yeah, I knew that, I was not sure if having wheels with different offset (from stock) would hit when the steering was was cranked all the way to one side or the other, any thoughts on that?Also, StevenD, wheel offset does not affect ride height.
