Got it back this morning, and I’ll give you the honest low down on what I think, and measurements.
Good news: It drives great, slightly stiffer than stock on bumps no doubt, but better than other lifted trucks and SUVs I’ve had by far. The shop even commented they were surprised at how well it drove compared to what they usually lift. I doubt the family will notice the difference.
Bad news: The 1.5” rear kit wasn’t enough initially, as it did not provide the expected 1.5” lift in the rear. There are many variables to what actual result you get, but this is admittedly disappointing.
Here’s what was put in:
[Before had about 40 lbs of gear in back, but no full size spare]
[After had full size spare ~67 lbs + 40 lbs of gear in back]
[Note that after measurements include a likely .2” added from new tire height]
Edit: After one short drive down a bumpy road, the front/rear gap has closed from .5” difference to .3”, so I’m going to give these a while to settle. If they don’t get to rear a hair higher than front, I’ll probably get the Traxda 2” rear kit and replace the rear 1.5.”
Disappointing the rear didn’t lift more, as would be more money than I need to spend, but we’ll see what happens.
Traxda has been awesome to deal with in many ways as they’ve gone above and beyond, so I still highly recommend them.
06/15/21 Edit after driving a couple of weeks, and with correct tire pressure:
Passport is driving fantastic now, and very close to stock. Even the initial harder bumps seem to have eased up, and it’s driving great.
After:
- Traxda 1.5” front kit
- Traxda 1.5” rear kit (which consists of (3) x .25” spacers, but due to angles and variables is said to lift the rear more than the physical .75”. In my case, this did not happen much)
- Ridgeline 18x8 OEM wheels w/ 55mm offset
- 255/60/18 Nitto Terra Grapplers
- Front: 33” / 34.6” (edit: 34.5” after a bumpy road drive | 3 month update: 34.25" both sides)
- Rear: 33.25” / 34.1” (edit: 34.2” after a bumpy road drive | 3 month update: 34" both sides)
- Ground to bottom of Curt hitch: 12.75” / 13.6”
- Ground to bottom of die cast running board: 9.75” / 11.1”
- Ground to bottom of front bumper: 9.1” / 10.5”
After:
