I was wondering what Honda was thinking with this radio on the sport trim not even apple play and to small they should have charged more money $ and put the same radio like the EX-L on the sport
That's what I did blue from the adapter to blue on the radio.Regarding the antenna adapter, my Kenwood only has one Blue/white wire on it's harness for either power antenna or amp. I'm assuming there is no separate amp in this trim level and plan on connecting that B/W wire to to Blue wire on the antenna adapter and leaving the Blue wire on the Metra harness empty.
Thoughts on this?
I am pretty confident I have the correct brown wire. There are 2 brown wires on the harness but I am going with the one that shows what he's pointing to.The reverse wire is a huge pain to get to there is a ridgeline video and he shows the wire. For that one take the lower panel off on the driver side it helps a lot.
He points out the reverse at about 7:40 in the video.
If I remember correctly there are 3 of the big plugs it was the top plug closest to the driver.I am pretty confident I have the correct brown wire. There are 2 brown wires on the harness but I am going with the one that shows what he's pointing to. View attachment 9535 this thing is a pain to get to
On my first attempt I tapped into the wrong brown wire it was the 2nd plug down but there were no damages it just didn't work.If I remember correctly there are 3 of the big plugs it was the top plug closest to the driver.
That thing was a pain to get to. All setup and so far all is good. I don't have source or call pick up/hangup from steering wheel controls but that's not a big deal. I check wiring several times and everything was done based on everyones info. Man, I could never have done this one without your help and all the others that have shared info. Thanks againOn my first attempt I tapped into the wrong brown wire it was the 2nd plug down but there were no damages it just didn't work.
Looks great glad it worked out.That thing was a pain to get to. All setup and so far all is good. I don't have source or call pick up/hangup from steering wheel controls but that's not a big deal. I check wiring several times and everything was done based on everyones info. Man, I could never have done this one without your help and all the others that have shared info. Thanks again View attachment 9538
I’m thinking of going back in and installing an aftermarket back up camera or maybe the toggle switch. I don’t like that fishbowl view at all.Looks great glad it worked out.
I would like to see that maybe an HD one if you can find something.I’m thinking of going back in and installing an aftermarket back up camera or maybe the toggle switch. I don’t like that fishbowl view at all.
I just need to look at the wiring set up to determine what I need to keep and remove to make sure I don’t screw up SWC with pin 12 and 24 in the camera harnessI would like to see that maybe an HD one if you can find something.
I've been digging through wiring schematics today for another project and I'm checking back on the radio wiring. It looks like the sub feeds directly off of pin 2 (Red) and 4 (White) and nowhere in line is there an amp. It looks like the head unit may have had the amp built-in. This view shows plug A (car wiring not the metra plug) out to the speakers. It would explain the thicker wires on the corners to handle the full power from the head unit to the sub.I just need to look at the wiring set up to determine what I need to keep and remove to make sure I don’t screw up SWC with pin 12 and 24 in the camera harness
Awesome! Looks like I need to start researching some amps that I can fit in dash to get that thing powered up! Can’t imagine I need much power but would plan on replacing the sub anyway as I am looking into changing out the speakersI've been digging through wiring schematics today for another project and I'm checking back on the radio wiring. It looks like the sub feeds directly off of pin 2 (Red) and 4 (White) and nowhere in line is there an amp. It looks like the head unit may have had the amp built-in. This view shows plug A (car wiring not the metra plug) out to the speakers. It would explain the thicker wires on the corners to handle the full power from the head unit to the sub.
This one shows the plug in the back where the sub connects to the rear floor harness.
The CD plug gray is the illumination wire so you were correct even though we knew it worked.
Something else that I realized the front tweeters feed off the same wires for the door speakers. They don't have any dedicated lines for them.I've been digging through wiring schematics today for another project and I'm checking back on the radio wiring. It looks like the sub feeds directly off of pin 2 (Red) and 4 (White) and nowhere in line is there an amp. It looks like the head unit may have had the amp built-in. This view shows plug A (car wiring not the metra plug) out to the speakers. It would explain the thicker wires on the corners to handle the full power from the head unit to the sub.
Hi, have you had any issues with this setup since installation? If so, anything you would do differently? I am still looking to replace the 5" unit. Thanks!Whatever you decide to do, there's info in this Ridgeline thread that may help.
Head unit replacement for 2017 RTL
Mine is still going great. I have not reconnected the sub it's still on my to-do list.Hi, have you had any issues with this setup since installation? If so, anything you would do differently? I am still looking to replace the 5" unit. Thanks!
Hi, Jomar 65 - did you ever find a unit to replace the crappy 5" stock unit? If so please message me. Thanks!I was wondering what Honda was thinking with this radio on the sport trim not even apple play and to small they should have charged more money $ and put the same radio like the EX-L on the sport
Do you plan on installing the new head unit yourself?Hi, Jomar 65 - did you ever find a unit to replace the crappy 5" stock unit? If so please message me. Thanks!
