The Elite model tailgate is completely electric, we found out the hard way when the battery went dead. Our jumper cables were in the nifty little compartment at the back of the vehicle. Fortunately, someone else had jumper cables. Not sure how it went dead, it sat for about four hours, the dealer says the battery was good, maybe we left it in Accessory mode? We now keep the cables under the front passenger seat.My sports model will, not such luck for the wife's ex-l model😄
This is why I asked in the first place. I have a portable jump start unit that I placed in the rear under floor storage area then I thought if my battery was dead I'd need to use it, but how would I open the tailgate to get it. I need to find a better place to store it.The Elite model tailgate is completely electric, we found out the hard way when the battery went dead. Our jumper cables were in the nifty little compartment at the back of the vehicle. Fortunately, someone else had jumper cables. Not sure how it went dead, it sat for about four hours, the dealer says the battery was good, maybe we left it in Accessory mode? We now keep the cables under the front passenger seat.
The latch is powered on pretty much all new cars so no. Without power it's impossible to unlatch unless you use manual unlatch.I'm wondering if the tailgate will open if the battery is dead. I know there's a way to manually open it but wondering if that works with a dead battery.
You could always go in one of the second row doors, put down a seat and reach/crawl into the back to get the jump starter. I keep mine in the driver side well compartment along with a fire extinguisher.This is why I asked in the first place. I have a portable jump start unit that I placed in the rear under floor storage area then I thought if my battery was dead I'd need to use it, but how would I open the tailgate to get it. I need to find a better place to store it.
Well there is always the emergency key in the fob to get into the vehicle. From there you could pop the hood, pull the battery, go get a new one and install it. Something I have had to do with my wife's Toyota when she had it and on my PU truck from many years ago.I didn't try, however in hindsight, it does appear one can crawl from the back seat like a snake and reach the bin.
For us now, the cables are under a front seat and we bought a booster, which is small enough to fit in the glove box.
Also, we stow a phillips screwdriver to remove all the ducting to reach the battery ground terminal.
I bought a cheap plug-in voltmeter to monitor the voltage, the dealer suggested to unplug it when the vehicle is off.
It is interesting, the voltmeter usually shows 14.1 volts (charging) but 12.1 or 12.2 volts when the battery appears to be fully charged.
That voltage seems a bit low to me but maybe normal for this car.
Yes, HarveyW, you are correct. The battery was drained to the point that the starter solenoid would not kick in but the doors opened.
A completely dead battery would probably need a tow to the dealer to wake up the Hal 9000 computer.
