1 - 5 of 5 Posts
Has anyone removed the warning label about metal objects on the wireless charger? I’d like to in favor of a cleaner look, but it didn’t seem to want to remove too easily and last time I tried a little harder to remove what I thought was a stubborn sticker, I ended up needing a new GoPro battery because I’m an idiot.
Technology Electronic device
If it's a decal you can use some form of Goo Gone. If it's heat screened (like the airbag warnings on sunvisors), then you may do more harm than good trying to remove it. Maybe cover the whole area with a thin mousepad-type neoprene that's cut to fit the size of the recess.
You're going to want to be careful with whatever chemicals you are using on that surface to try and remove the sticker. I've had good luck getting tough ones like this off with a hair dyer. Should help dry up all the adhesive.
1 - 5 of 5 Posts
