Thanks! Wonder why our mileage is better at a higher speed. Yes, comparing apples to apples on the same stretches of interstate in similar conditions.With a very light throttle, 7-8 @ 48 mph, 8-9 @ 65 mph.
Engine RPM is lower at 9th gear at your posted speed(s) than lower gear(s) at your posted lower speed(s)scooter1 said:Wonder why our mileage is better at a higher speed.
That's why I asked. Thought it was odd, but remember someone said they thought the shift points were at higher speed. To reiterate, comparing apples to apples, same roads (flat I-95 in NC, SC, GA), different average speeds, using the dash calculator. More than once we've had better mileage going a bit faster.Heh? The speeds the OP listed would indicate he is always in 9th. (73-75 than at 70-72.)
But if strictly going by the dash indications, I wouldn't put a lot of faith in those numbers.
Could you please post the ScanGauge codes for current gear?I can now display current gear on my ScanGauge. Next chance I get on the road I'll check it out. I usually see 8th around town on speed limits of 45 and 50, but will try a slow acceleration to see when those 2 actually shifts.
