Don't know about your manual, but my 2020 Passport Owners Manual shows differently:The maintenance minder should bring up code 3 when change is needed. Here is the sub note for specific conditions.
*3: See information on maintenance and emissions warranty in the first column on page 589. If you drive in dusty conditions,replace every15,000miles(24,000km).
I think you will find a transmission fluid change video or walk through helpful but I don't believe anyone here has done one. The only thing that comes close is the Rear Differential Fluid Change walk through by @DudeCS. Maybe a YouTube search will turn up something useful.Thanks to everyone for their help! I am going to wait until 60k or when the Code 3 reminder comes on. Just to wrap up the discussion here, is there a filter inside the transmission? If so, can or should one change it?
I am at 63K miles and ready to change the fluids in the transfer case and transmission. The transfer case is easy and straight forward, but I have to buy a quart of the gear oil. The transmission fluid is more involved. There are videos for the transmission fluid. TBD if I will DIY the transmission fluid.I think you will find a transmission fluid change video or walk through helpful but I don't believe anyone here has done one. The only thing that comes close is the Rear Differential Fluid Change walk through by @DudeCS. Maybe a YouTube search will turn up something useful.
Considering his Pilot has a 6 speed transmission, is the fluid replacement procedure (and fluids) the same for the 6 Speed and the 9 speed?I am at 63K miles and ready to change the fluids in the transfer case and transmission. The transfer case is easy and straight forward, but I have to buy a quart of the gear oil. The transmission fluid is more involved. There are videos for the transmission fluid. TBD if I will DIY the transmission fluid.
Here is a video for changing the fluid for the transfer case (Honda Pilot)...
Unfortunately, no. The 9 speed is not a spill and fill. It's an involved procedure that requires the wheels moving with the car lifted and a Honda scan tool. There are ways around this and there are folks that have done spill and fills thought. When the 9 speed first come out, the fluid was over $40/qt. it has since come down but it's very expensive.Considering his Pilot has a 6 speed transmission, is the fluid replacement procedure (and fluids) the same for the 6 Speed and the 9 speed?
Yes. I still have to confirm the quantity required. I thought it may be 4 quarts for the refill? To check the transmission fluid temperature, a suggestion was to use a handheld infrared temperature gun to check the transmission case. Also, VSA has to be put into maintenance mode. I've printed off the instructions and tried it. It is like rubbing your belly with one hand and your head with the other hand. That is, you have to follow the sequence precisely.Unfortunately, no. The 9 speed is not a spill and fill. It's an involved procedure that requires the wheels moving with the car lifted and a Honda scan tool. There are ways around this and there are folks that have done spill and fills thought. When the 9 speed first come out, the fluid was over $40/qt. it has since come down but it's very expensive.
I guess the search for a Passport transmission fluid change procedure video continues...Unfortunately, no. The 9 speed is not a spill and fill. It's an involved procedure that requires the wheels moving with the car lifted and a Honda scan tool. There are ways around this and there are folks that have done spill and fills thought. When the 9 speed first come out, the fluid was over $40/qt. it has since come down but it's very expensive.
Below are the videos for the transmission fluid change on an Acura.I guess the search for a Passport transmission fluid change procedure video continues...
This is from the Pilot forum. When the time comes I'll probably do a spill and fill with 3.5 qts. after I see more folks doing it.I guess the search for a Passport transmission fluid change procedure video continues...
How many miles are you at? They say that the transfer case should be changed at the same time. That's supposed to be an easy one, just have to source the HPO fluid. All I can say is there's a sticker on the trans that says something like fill with 3.5 qts. type 3.1 fluid. Some say that these transmissions are super sensitive to fluid level. My thoughts are if the factory fill is correct and if you drain cold fluid and refil with fluid at the same temperature how can you go wrong? Here's another video that sold me on the fill and spill.
