I was thinking about adding the transmission cooler to my Passport, i.e. a cooler transmission equals longer life. Then I had a conversation with a mechanic buddy at the local diner recently, he suggested not to install the separate transmission cooler. He said, in many other vehicles with an automatic transmission the transmission cooler is placed inside the car radiator. The car radiator provides temperature regulation, i.e. it warms the transmission up when it is cold and keeps it from getting too hot. There are a lot of very sensitive parts and tolerances inside a modern transmission. I can see driving in a frigid Ontario winter, with the separate cooler keeping the transmission ice cold all day. And separate coolers only work by air flow, compared to a cooler inside the car radiator, which again is in a temperature controlled environment. Does any one have experience with this issue? Am I missing some detail, like the transmission has a thermostat or something? Are there any other Honda models with the transmission cooler in the radiator? And too bad the manufacturers don’t have a transmission temperature read-out; based on the level of technology in this vehicle, it could easily be programmed to record and send the temperature history to your phone.
