In PA, I was quoted $570 last week. Cooler only. I installed a Curt Hitch ($175) and the wiring ($50) from Amazon. It was an easy install, 6 bolts, it does take 2 people. The hitch is very well made. The wiring was all plug and play. I did have to drill 2 holes for the tin wire plug mount. I need the 7 connector round plug, all my trailers already have that on, so a little less if you are rocking the 4 flat. The only con was it sits a few inches lower that the Honda, so it might affect departure angles if that is an issue, pros: no need for that extra plastic, the kick sensor seems to still work on the side of the hitch. I would recommend it.
