1 - 7 of 7 Posts
Are the trans fill and level plugs one-time use? Just put a cooler on and the kit comes with all three plugs.
There are three plugs... drain, level, fill. Search for YouTube videos "transmission fluid 9 speed acura". Pay attention to the refill proceedure.
Discussion Starter #5
Yes, I did install the OEM cooler. The install took me about 6hrs. some parts like the air dam I just loosened and screwed the cooler in from the front lower grille. You will have bloody knuckles when you are finished it is tight. Don't be scared about pulling the hard lines from the trans you will lose fluid. If anyone has any direct questions about the install I'll help the best I can.
2020 Passport Elite - Future Purchase
Thanks. I’m wondering if anyone has installed an aftermarket tranny cooler?
I’m not sure I’d go aftermarket with a trans cooler. If something happens to it and the trans suffers a failure, Honda may throw up their hands and show you the door. That’s unless you agree to pay them for the new trans. 🙂
1 - 7 of 7 Posts
