Yes, but it won’t reach there. The cable isn’t long enough.
Yes, but it won’t reach there. The cable isn’t long enough.No, I am referring to the control box. Once installed you have no need to access it and the center part of the console/lower dash area under the head and radio unit has a nice bit of space. Out of site out of mind.
What blank did you purchase to fit into the factory plug?I installed a Redarc TowPro Elite in preparation for towing a Tab400 travel trailer out to Glacier NP next week (untested). Used the spare spot next to the traction control button. Hid the main box up under the dash (secured with zip ties) and plugged it direct into the under dash wiring harness. Easy peasy. Hardest part was getting the damn plug blank out.
I got the universal one on Redarc’s web page where I bought the controller and cable. It did need minor modification since the Redarc blank is round on the back and the slot is rectangular. It was minor. You can see the mod needed in post #27 above.What blank did you purchase to fit into the factory plug?
Mine came with the universal blank.What blank did you purchase to fit into the factory plug?
Come to think of it, the universal one may have come with mine too! I just remember that there was no special one like there is for some other makes.Mine came with the universal blank.
How did you pull of the left side dash panel? Would like to do this but don't want to break any plastic clips in there. Thanks!@Macmuchmore I installed the control knob as Clark Griffin shows in post #27 above and the control box on the metal vertical dash support to the right of the steering wheel post. I had pulled the left side dash panel partway down and could see this vertical support, then secured it with zip ties criss crossed through the mounting holes. It is very secure at this point but if there are any issues in the future, I can make a bracket to attach it with screws.
I went to Bernardiparts.com and found the instructions to install a CD player which requires disassembly of the dash and followed step 8 where it shows how to take apart the drivers side of the dash.How did you pull of the left side dash panel? Would like to do this but don't want to break any plastic clips in there. Thanks!
This is very helpful! Does the doorseal just pull away without any problem, or is it attached somehow? Also, did you simply pry off the Dashboard Side Lip or do you need to do something more to get the 3 clips to release? Same with the driver’s dashboard lower cover? Thanks again for sharing your experience.I went to Bernardiparts.com and found the instructions to install a CD player which requires disassembly of the dash and followed step 8 where it shows how to take apart the drivers side of the dash.
The seal just slides away from the door edge - it is held in place by the metal in the door jam. The seal has a channel in it that fits over the metal jam. The dash is held in place by plastic clips (look at step 8 of the instructions I attached). Yes, same on both sides, just use a plastic trim tool and pry outward.This is very helpful! Does the doorseal just pull away without any problem, or is it attached somehow? Also, did you simply pry off the Dashboard Side Lip or do you need to do something more to get the 3 clips to release? Same with the driver’s dashboard lower cover? Thanks again for sharing your experience.
I tried looking for this, but I was given two options. Either the Pilot or Ridgeline setup. Do you have a link where you bought yours or do you recall which version you purchased?I installed a Redarc TowPro Elite in preparation for towing a Tab400 travel trailer out to Glacier NP next week (untested). Used the spare spot next to the traction control button. Hid the main box up under the dash (secured with zip ties) and plugged it direct into the under dash wiring harness. Easy peasy. Hardest part was getting the damn plug blank out.
Hey, by any chance did you figure out how to test this without having a trailer in the back hooked up? I just installed mine but it was not turning on, and the Redarc employee said that was normal until something was plugged in.Congratulations! I am in the middle of the install. I’ve checked all my wiring connections and they are good, but when I turn the car on, the remote head assembly LED doesn’t light up, because no trailer is attached. I’m going to call for support today (if they are open) and ask how I can test to make sure it is working, without a trailer (haven’t purchased one yet).
If I may ask, where and how did you mount the main unit, and did you use the Honda supplied 20amp fuse, or did you use a 30amp fuse as recommended by Redarc?
Thanks!
I got everything hooked up, but it will not turn on. I even tried plugging my trailer to see if it would turn on but nothing happened. I used the same setup as you. Did you need to install a fuse?Check out my prior post (post #7) in this thread.
Towing Brake Controller
Assuming you mean the Honda-specific cable to connect the Redarc unit to the tow harness under the dash, I bought the TPH-013 cable direct from Redarc. It's listed on their website for Honda Pilot and Ridgeline (and Acura) but it will work for Passport - same exact harness under the dash...
Acura/Honda suitable Tow-Pro Brake Controller Harness (TPH-013)
