Anyone installed a brake controller before on your Passport? I’ve got a Prodigy 2 and am not sure the best place to mount it. I wanted to put under the radio area in the center console. Where have you put them??
Nice clean install. Looks good.I installed a Redarc TowPro Elite in preparation for towing a Tab400 travel trailer out to Glacier NP next week (untested). Used the spare spot next to the traction control button. Hid the main box up under the dash (secured with zip ties) and plugged it direct into the under dash wiring harness. Easy peasy. Hardest part was getting the damn plug blank out.
what part did you plug into the wiring harness? something just to get power?plugged it direct into the under dash wiring harness. Easy peasy.
When purchasing OEM Honda Trailer hitch, among the parts INCLUDED with the hitch is the trailer brake controller wiring pigtail shown below, along with required fuses to be inserted in engine compartment fuse box, positions 2 (block fuse), position 3 (electric brake), and position 11 (power/charge).It's a four (? or five?) wire harness that provides power, ground, and brakes connection to the 7 pin trailer connection at the tow hitch. Factory installed (regardless of getting a tow hitch installed I believe?) under the dash for you to connect in (any) electronic brake controller. You can use the bare wire connecting plug that comes with the tow hitch install to wire in the controller or some brands have custom prewires with matching plugs available. Curt and Redarc have Honda-specific custom wiring "connectors."
Thanks, for the information, I will certainly have to consider the Radarc.HarveyW, I had also considered the Curt Spectrum controller but decided that A) the blinking lights with no trailer attached (which is most of the time) would be too bright and distracting (per a lot of reviews), and B) the dash control knob was a lot bigger in diameter and I was concerned that I would be forced to drill a hole in the dash somewhere to mount it. Wasn't keen on the double-sided tape surface mount option.
The Redarc unit avoided both issues for me - no blinking lights when no trailer attached, and the smaller knob profile meant it would fit the spare button knockout already in the dash. Plus it has a "user-controlled mode" (fixed direct-set brake power) in addition to the proportional mode that the Spectrum has.
Redarc even had a molded universal dash plug (seen in pic above) that pops in, after a little "adjustment" of the surrounding hole in the dash (needed some clearance on the sides for the rounded rear flanges on the insert, FYI).
Final decision was made easier in that the Redarc unit was cheaper.
Just something to consider. YMMV.
Have you been happy with the Passport in general, towing a Nucamp 400. I keep reading it’s too heavy for the Passport, which is bumming me out a lot, as I thought I could pull 4,000 lbs safely when I bought the Passport. Thanks.OK back after ~3870 miles over 11 days towing a NuCamp Tab400 travel trailer (rental) out to Glacier NP and a wide return swing thru WA, OR, & ID before returning to MN. As seen, averaged 13.4mpg.
Redarc brake controller performed flawlessly. It self-calibrated without issue and was very easy to adjust on the fly. And we definitely put it through its paces driving up and down the mountains (lots of switchbacks). Very happy with the install.
Thank you! Very helpful!VERY happy with the Passport in general. No issues at all towing that NuCamp or any smaller trailers (like U-haul 5x8 or 6x12).
The NuCamp was a one-time rental thing so other than that one (long) trip, I can't really comment for "in general" feel. What I can say is that, given where we went (Glacier NP, up & down lots of hills/mountains in WA/OR/ID/MT) I felt that the Passport handled that loaded NuCamp (prob not quite 4000lb "dry" with whatever gear we had stashed in it) like a CHAMP. And that was with a bunch of heavy gear in the PP itself (to cut down on "dead weight" in the trailer). It got up to speed very fast on level/downhill highway, was reasonable (within expectations) for uphill acceleration, and maintained a straight line (with weight distribution hitch) no problem. In fact, we never had even one trace of instability caused by passing other traffic.
I used D mode in the level sections and S mode for the inclines/declines. I thought the paddle shifters worked very well for forcing some downshift engine braking on the steep curvy downhill sections.
If I had ONE complaint (OK two) it is this:
Overall, I guess my comment would be this - if I'm renting that NuCamp Tab 400 once a year for a trip, I wouldn't change a thing. If I was actually going to buy a RV trailer, I would look at something (the trailer) a little smaller (while still having a bathroom - that's essential in my book) for my PP to pull around. Not so much due to the weight (although that IS a factor), but more for the exposed frontal area that creates too much wind resistance. In other words, I bet you could pull a 4000lb pop-up trailer (that is smaller than PP frontal profile when collapsed for travel) and get much closer to the "no trailer mpg."
- The standard (FWD/AWD) PP doesn't come with any towing capacity at all. You have to install a tow hitch (and other stuff; not cheap). That seems bogus in today's world - all SUV/CUVs should come standard with tow hitch IMHO. AND then once you add the tow hitch, the (AWD) PP only has 3500lb towing capacity. If you want to bump that to 5000lb you have to install the tranny cooler (also not cheap). 5000lb is OK for SUV/CUV but pretty wimpy for most big RV trailers. And who (not many) can afford to have a dedicated $50k+ tow truck? On the plus side it does come prewired for dash-mount electronic brake controller (required for towing anything over 3000lb).
- Gas mileage dropped a LOT. I had read on this forum about someone else who owns a NuCamp and warned that they get normally 13-14mpg when towing it (it actually does have quite a big "frontal area" pushing wind despite being a teardrop shape) so I wasn't caught totally unawares but I expected that kinda gas mileage in the hills (further west on our trip) not in the flat sections. I jumped on the (very flat) highway out of Minneapolis and set cruise at 75 like usual and had to make adjustments very quickly (only doing ~9mpg at that speed). Didn't want to stop for gas every 150miles...
Not worried about MPG, mainly safety. Thanks!People who are new to towing or do not tow a lot seem to forget, that with the Passport you have a six cylinder 280 HP gas engine to move a 4000 pound vehicle. Add a 4000 pound trailer to it and you are asking the same vehicle to move the equivalent of TWO Passports with the same six cylinder 280 HP gas engine. You are putting twice the strain on the engine, transmission, differential etc. Gas mileage is going to suffer, no matter the shape of what it being towed. 8000 lbs is still 8000 lbs.
My towing vehicle, a 3/4 ton Cummins Diesel has a towing capacity 5 to 6 times greater than a passport. Even then when towing a trailer my mileage goes down. Not to bad with a 4000 pound weight behind. It's worse when I tow a 20000 pound weight. Bottom line my PU was built for the purpose of towing/carrying heavy loads, The Passport was not built for the purpose of towing but for hauling passengers.
