Hi All,
Building up as best as possible with the limited accessories available.
Ordered Truxxx 2" suspension spacer to "level" things out. Waiting for the delivery.
Been pouring over tire sizes and if it all works out I'll now be getting new 255/65R18's (31.1 × 10) in the hope of gaining a little height without rubbing. I think staying a little narrower will help gain a little more height instead of maximizing height and width...
For the time being today I had used 265/60R18 Dean Back Country tires (picked up yesterday) mounted on lightly used Ridgeline wheels (picked up a few days ago). When I rolled the stock 2021 wheel/tire combo up next to the current set I found the "larger" 30.5 inch tire is the same size as the "smaller" 29.6 inch stock tire.
Before:
After:
What i noticed afterwards:
1. Softer ride - actually absorbs harshness.😎
2. Louder - hums from about 20-55 mph. May be normal or from improper care. They did balance quickly on the Ridgeline wheels. Not the best all around tire IMO (used and somewhat of an off brand sold exclusively at Les Schwab). New they're as pricey as BFG's, Cooper, Falken, etc...
3. Great traction in the dirt, gravel and mud (no deep mud)🤠
4. Now I can fly down dirt and gravel roads. I can even air down. 😱
5. They are not taller, like they're supposed to be. Maybe because about half the tread is gone? 🙃
6. Wider feel from tires (10.4" vs 9.6" stock) and a little more prone to start to step out or break loose in the rear around corners on wet paved roads.
Here's from today:
Before:
After:
Here's from today:
