I tried to thread a wire into my passport via the passenger firewall grommet - big mistake - it turns out the loom splits AND there's the ventilation/air handler unit in the way. I've done this 2x before, and this was the worst attempt I've ever made that was unsuccessful. Two things made this hard:
1) There's a hard plastic firewall skin on the cabin side of the firewall at parts.
2) The loom splits in multiple directions as soon as it gets past the grommet.
I used a coat hanger, and made an ultra tight curl around a 3.5mm jack for my camera that I was wiring through the grommet. I poked through the top of grommet and then angled the wire to the passenger side of the car to get around the air handler. I took the glove box and glovebox trim off for better access, but the air handler was still in the way.
I found the coat hanger, and pulled on it but it was really stuck. I realized the tight curl for the 3.5mm was probably snagged in the OEM wires. I tried to push the coat hanger wire back out, but was unsuccessful. After scratching up my arm alot from all the reaching, I finally gave up and left the coat hanger in the loom. Patched the grommet back up with some 3M gasket maker, and called it a day.
Absolute waste of time, and super sad about it. I've done this in my s2k and my honda fit with no issues at all, but this car really stumped me. If the air handler wasn't in the way, I think I could've made this work out.
Does anyone know where I can get instructions to remove the air handler behind the glove box? It looks difficult to remove...
