1 - 7 of 7 Posts
Want to find out what other PP owners think about Wheels you may be considering?
YOU CAN POST THEM HERE
Here is one that I like, it is 18 x 8, with 45mm Offset, it should stick out less than 1/2 inch over the stock wheels. Price wise at $189 per wheel, it is quite a bit less than the $200-$300 each wheels form brands like KMC and Black Rhino...!
Any thoughts on thees wheels are more than welcome...
With that much positive offset, I wouldn’t think they would stick out any farther than stock......not noticeable anyhow.
Discussion Starter #3
Well if I recall correctly, the factory wheels have an 55mm offset, so the difference would be only 10mm. And if 0.5" = 12.7mm, it would be around 3/8", which should not be very noticeable..!
Since most tire experts agree that taller sidewalls have a smoother/quieter ride, let us know if you can tell a difference.
Discussion Starter #5
Let us know how much quieter, smoother you feel the taller sidewall tires are.
I will! But I am only in the pre-pre-pre-planning stages, I may not upgrade for another 1-2 years.
I'm learning towards the Nitto Grappler2 266/60R18, however I do not want to have to do a lift kit, so I'll need to confirm there is no rubbing with that combination..
Cheers!
I would think if you have at 1/2” plus clearance with the stock tires at full wheel lock both ways (left/right), a 1” taller tire would clear as well. Those wheels look great, should be easy to clean.
Those Sport wheels look nice, but you need to be aware of a few things. I bought a winter tire package a few years ago from Tire Rack that included Sport wheels. I installed them with a torque wrench yet the lug nuts kept coming loose. Turned out the contact point where the lug nuts met the wheel were different, meaning one surface is more rounded than the other. Tire rack agreed and had to send me new lug nuts compatible with the Sport wheels. Also, I thankfully noticed that the OE lug wrench did not fit into the openings of the Sport wheels. So I had to carry a regular socket set with me at all times. Eventually I bent a Sport wheel on a pothole and could not get a replacement since the style I bought was obsolete.
Although more expensive, I went with these wheels and Michelin Defender LTX tires:
Nice ride and no wheel damage when my teen drivers rub on curbs.
1 - 7 of 7 Posts
