18" Ridgeline wheels fit perfectly, here are mine. Passport brake rotors are so small that 17" wheels should fit as well.
What was your primary reason to put 18” wheels on?18" Ridgeline wheels fit perfectly, here are mine. Passport brake rotors are so small that 17" wheels should fit as well.
Primary reason is that with 18" wheels I can drop the air pressure when driving in sand on the beach. Taller sidewalls allow for a much bigger "footprint" and more float in soft sand. Dropping the air pressure on 20" low profile tires does not improve sand traction much.What was your primary reason to put 18” wheels on?
I find my Elite rides “rough” even on smooth roads. Feels like every road is gravel.
Do they 18s help the “rough” ride?
Do you think the Michelin Premier LTX on the stock wheels would make a difference to the ride quality? Assuming they Michelin’s come in that size.Primary reason is that with 18" wheels I can drop the air pressure when driving in sand on the beach. Taller sidewalls allow for a much bigger "footprint" and more float in soft sand. Dropping the air pressure on 20" low profile tires does not improve sand traction much.
As for ride quality, I don't notice much ride quality difference with the 18" wheels. However, I went with 18" Michelin Defender LTX tires which have a deeper, more aggressive tread pattern so they are not as smooth. If you go with 18" wheels and Michelin Premier LTX tires you would have a much smoother ride.
Thanks, that gives me better insight.Primary reason is that with 18" wheels I can drop the air pressure when driving in sand on the beach. Taller sidewalls allow for a much bigger "footprint" and more float in soft sand. Dropping the air pressure on 20" low profile tires does not improve sand traction much.
I would think so based on my experience with that tire. By far the quietest and smoothest tires I have ever bought.Do you think the Michelin Premier LTX on the stock wheels would make a difference to the ride quality? Assuming they Michelin’s come in that size.
Way, way, way too much, new 18" tires and wheels run about $2,300..!I'm being quoted $4k for ridgeline rims and tires instead of the the 20 inch default tires. Does that make sense?
Agreed, way too much. I found a very nice set of used 2109 Ridgeline wheels on OfferUp locally for $450. The are 18x8 with an offset of 55.I'm being quoted $4k for ridgeline rims and tires instead of the the 20 inch default tires. Does that make sense?
