A photo would be good.
I checked again and it is a crack. I don't remember dropping anything on it. Very strange. I wonder how much that part is to replace. I will most likely not replace it since it is not very noticeable but just curious.is it a crack or just a deep scratch? hard to tell in the pic. I ask because I used to install interior trim parts and when ones like that would break they would shatter/explode vs tiny cracks like that. EDIT: I see two little white marks at both ends of the crack, was something dropped there?
You can replace the part for ~15 dollars. I think it is 84251-TG7-A00ZA.I checked again and it is a crack. I don't remember dropping anything on it. Very strange. I wonder how much that part is to replace. I will most likely not replace it since it is not very noticeable but just curious.
Thank youYou can replace the part for ~15 dollars. I think it is 84251-TG7-A00ZA.
I've taken my door sill trim off a bunch of times for running wiring or vaccuming, and it is fairly strong as long as not removed improperly. My guess is you got a bad part or it was removed improperly at some point.
Take it to your local dealer. See if they will replace it under warranty. If your out of your warranty period they might do it as a good will gesture.Thank you
