Here is a documented 6K service (per service manual) I completed myself. Yes It's my motorcycle but it's no different than what I would do to my 4 wheeled vehicle at the required service intervals.
The only 2 things I did outside the parameters of servicing was replaced spark plugs (service requirement is to pull and inspect) and opened the fuel reference screw on throttle body to get rid of the factory lean bog off idle. Everything else is by the book.
6K service 06/24/20 5578 miles:
Rear brakes disassemble, measure, inspect, clean, lube sliders
Outside pad upper 4.53mm
Inside pad 4.45mm
Rear pad wear limit .8mm
Rotor thickness 4.97mm
Rear rotor wear limit 4.5mm
Rear rotor runout limit .15mm
Front brakes disassemble, measure, inspect, clean, smooth out pin
RF outside pad 4.43mm
RF inside pad 4.30mm
LF outside pad 4.47mm
LF inside pad 4.30mm
Front pad wear limit .5mm
Left rotor 4.46mm
Right rotor 4.43mm
Front rotor wear limit 4mm
Front rotor runout limit .10mm
All pad measurements taken from middle of pad
Spark plug replacement
Air filter replacement
Check coils ohm rating:
#1 primary 1.5-1.6, secondary 9.94
#2 primary 1.5-1.6, secondary 9.90
#3 primary 1.5-1.6, secondary 9.98
#4 primary 1.5-1.6, secondary 9.76
Primary range spec: 1.19-1.61 ohms
Secondary range spec 8.5-11.5 ohms
Mount/balance/check spokes new Michelin Road 5 tires
Inspect, clean/lubricate hub sleeves and rear gear
Pull pumpkin, inspect, clean/lube splines and gears
Replace diff oil
Inspect steering head bearings
Inspect fork bushings (right one has a small amount of play)
Install wheels front and rear
Synchronize throttle bodies (open right reference to 3/4 turn)
Check throttle free play (no free play per my preference)
Lubricate, kick/center stands, shifter/rear brake shafts, clutch/brake lever pivot pins
Whenever I have my tires rotated (during fluid change) my local mechanic pulls the calipers, inspects and measures pads/rotors and lubes the pins. It's all part of the facilities inspection/service procedure.
It's a AAA approved facility and I have established a relationship with the owner over the years. In return of stellar service I bring a clean vehicle and detailed work order on what needs to be performed.
Bottom line is the B16 is going to be done and done right. The service manager knows right away I'm no one to trifle with. I'm polite but firm. My first B service is free and the dealership will do every single item on the list.
