For DIY install of the "seat back protector" or "cargo side panel protectors", the installation calls for a Rotabroach cutter. The tool is for cutting holes in the seat back (8mm) or cargo side panel (6mm) for inserting snap hardware or rivets, respectively.
Before I perform the actual install, I tested the Rotabroach cutter on a piece of vinyl siding. Photos as follows:
The only place that I found online for the cutters was directly with Blair Equipment or via Amazon. The cutters came in a 3 pack, unfortunately. I'll sell the cutters and arbor when done.
- 8mm cutter (top left), 6mm cutter (top right), small washer for arbor with small cutters, large washer for arbor with large cutters, arbor that attaches to a handheld power drill
- assembled arbor with small washer and 8mm cutter (the cutters are very sharp)
- pilot hole with 1/8" drill bit (left) and 8mm hole with arbor & 8mm cutter
Order information for Blair:
Rotabroach Arbor (11122)
8mm Rotabroach Cutters (11208-3)
6mm Rotabroach Cutters (11206-3)
