1 - 6 of 6 Posts
2019 Elite
What is the PPs roof weight limitation (using the OEM roof rack / outfitted with OEM rails)?
The box that I'm considering weighs 65 pounds - and is rated to hold 100 pounds of cargo / for a total of 165#.
I don't believe I'd ever load it that heavy but am interested in knowing what Honda says is allowable.
You are in luck Wrascal. According to Honda’s website the load capacity is 165lbs, exactly what you need.
From Honda:
“When you attach the Honda crossbars to the roof rails, you can securely transport items on top of your vehicle. It helps prevent damage to your interior and provides more space and comfort for your passengers.
  • Extruded Aluminum and Capron Resin long-lasting, sturdy construction.
  • 165 pound load capacity
Requires roof rails
Fits:
  • Passport: 2019, 2020
  • Ridgeline: 2017-2019”
Is that the limit per rail? I was thinking of having 4 rails to support more load
1 - 6 of 6 Posts
