I do the same,, though closer to 35 cold then 33. The OEM Continentals are showing a noticeable amount of edge wear after only 25000km, tread depth is <6mm on the walls vs 7.5mm at center so bear that in mind if you want the tires to last as long as possible.I dropped the pressure to 33 psi and this made a big improvement in ride quality with very little difference in handling.
We put 18" winter tires on this year, noticed a slight improvement in the 'boatiness' but its still an unnecessarily rough ride. My takeaway after 3 years: the AWD system is amazing, the ride quality sucks.
