Is there a feature that permits tail lights/ headlights to activate and remain on when the vehicle has been remote started? Currently the lights flash on and off when it is starting, but no indication after that the vehicle is running.
on the remote, hit unlock, then lock 2x, then the start button... you're welcomeIs there a feature that permits tail lights/ headlights to activate and remain on when the vehicle has been remote started? Currently the lights flash on and off when it is starting, but no indication after that the vehicle is running.
Just spit balling here but what would happen if you leave your headlights on "Auto"? If it's dark outside, maybe the auto light system will keep the lights on.The above method listed by "mvacolnago" does not work. The lights come on when you press unlock, but go off when you go through the auto start process. Dang, I was hoping it might work![]()
