Me too!I would really like to disable the beep when opening the rear liftgate.
Is the setting to put it in manual mode in the settings on the infotainment system? I primarily just want to turn it off when I'm camping to be nice to the neighbors. Manual would not bother me for that.I also wanted to disable the beep. Since I do a lot of camping, it annoying when trying to make a stealth departure before sunrise. My work around is to set the lift gate for manual mode and then just open and close manually with no beep. Its still not silent since the lifting is power assisted, but it works for me. Just another option...
Thanks, that really helps!Yeah sorry I couldn’t get my phone any closer, it’s the two wire connector in the center. View attachment 4046
it’s located behind the rear bumper if you crawl underneath with a flash you can see it. It’s a small relay sized box mounted to the body with a two wire connector connected to it. If you press the lock/unlock button on your FOB while you’re under there you’ll be able to tell that’s where the noise is coming from.
Yes there is a setting to change the left button to manual open vs the default button press which beeps and then opens the tailgate. I have left mine set that way. If I want the power assisted open, I can just activate the sensor with my foot.Is the setting to put it in manual mode in the settings on the infotainment system? I primarily just want to turn it off when I'm camping to be nice to the neighbors. Manual would not bother me for that.
Please clarify...I can set the the tailgate to manual mode so I can lift it to a height that will not hit my garage door? What page in the owners manual addresses this?Yes there is a setting to change the left button to manual open vs the default button press which beeps and then opens the tailgate. I have left mine set that way. If I want the power assisted open, I can just activate the sensor with my foot.
Yes you can use manual mode to only partially open the tailgate, but there is no way to set a limit; you would have to keep your hand on the tailgate to stop further movement.Please clarify...I can set the the tailgate to manual mode so I can lift it to a height that will not hit my garage door? What page in the owners manual addresses this?
Well that was easy. 60 seconds with screwdriver and needle nose pliers. No more obnoxious squawking! I just unplugged it and left it in there.In fact if you have small hands or some patience you can reach the connector underneath the rear center behind the bumper and just unplug it
Have you had any issues since disconnecting? Do you have any better pictures of what to unplug? Thanks!Well that was easy. 60 seconds with screwdriver and needle nose pliers. No more obnoxious squawking! I just unplugged it and left it in there.
