That's great! Glad everything worked out and no spills!
I believe its at 15k for the first time and then every 30k miles after that for normal usage or half of that for severe usage.At what mileage was this done? Good post!
15,190At what mileage was this done? Good post!
Yes, your Passport comes with Break In Differential Oil (AWD Models) and recommended replacement oil at 15K and had dealership preform this for $125!I believe its at 15k for the first time and then every 30k miles after that for normal usage or half of that for severe usage.
The car computer will tell you when it needs to be done.
So will the car computer let you know when the first change must be done?Yes, your Passport comes with Break In Differential Oil (AWD Models) and recommended replacement oil at 15K and had dealership preform this for $125!
Mine didn't, when I took it in for service, the service writer told me about it and naturally, I had them preform the work! If, you have any other questions, I'm here!So will the car computer let you know when the first change must be done?
I am just gonna do it when the time comes. It's not that hard.Yes, your Passport comes with Break In Differential Oil (AWD Models) and recommended replacement oil at 15K and had dealership preform this for $125!
You will not have a problem. I fit easily just sliding underneath. Im more round than flat lol. I didn't want to use the pump for various reasons. The extension tube works great and easy.Time for me to change the rear diff fluid, so I came here looking for tips. I was going to ask for recommendations on a fluid transfer pump, but I like how you were able to do it with just an extension tube/nozzle. I went out to take a look at how much room there is and I have to say, I'm impressed that you were able to fit under there and hold the bottle up high enough to fill. Not sure I can be as successful as you were. Anyone else able to do it without a pump?
I used a pump the first time but used the gravity tube/ nozzle method the 2nd time which was much easier and faster. Plenty of roomTime for me to change the rear diff fluid, so I came here looking for tips. I was going to ask for recommendations on a fluid transfer pump, but I like how you were able to do it with just an extension tube/nozzle. I went out to take a look at how much room there is and I have to say, I'm impressed that you were able to fit under there and hold the bottle up high enough to fill. Not sure I can be as successful as you were. Anyone else able to do it without a pump?
Like at my local dealership. It's $168.Yes, your Passport comes with Break In Differential Oil (AWD Models) and recommended replacement oil at 15K and had dealership preform this for $125!
Mine went off at around 10k, but it the car is now three year old so it might be a mileage/time sensor.Mine called for the diff fluid change recently at 12,500 miles.
