1 - 7 of 7 Posts
Hello everybody, so I had a thought cross through my head recently. For those with lift kits and bigger tires, have you ever had a flat? If so, does the stock jack work with the new height of your vehicle? It’s raining today here in Jersey so I can’t see if the stock jack will lift the vehicle high enough to change the tire so I figured I’d see if you guys ever ran into this situation. Thanks!
2020 Passport Elite
You are only lifted a few inches.... just carry a small piece of 2x6, maybe 2... jack problem solved.
I am interested in if you can get a bigger spare and if it fits the same storage compartment. I am guessing you can not run different size tires on an AWD.
2020 Passport Elite
What do you use the rest of the time, if your flat is in daily traffic? Can you get a larger doughnut and will it fit in the in the normal spot? or is it ok to run the smaller?
I have been driving around with the donut in the spare compartment. Check out this thread, very similar discussion:
1 - 7 of 7 Posts
