1 - 3 of 3 Posts
Wiring in my dash cam and I'd like to use a piggy back fuse at the fuse panel for the 12v power plug under the dash. Only problem is the manual doesn't identify the fuse that the 12v power plug uses and you need to be a contortionist to try to read the panel diagram on the kick panel on the drivers side. Does anyone know which fuse it might be? I have found pictures of the panel but none identify that plug fuse.
Thanks in advance for any help you can provide.
1 - 3 of 3 Posts
