201 - 203 of 203 Posts
RIMS:
Brand: Black Rhino
Model: York
Part #: 1880YRK355120M76
Color: Matte Black
Diameter: 18"
Width: 8"
Offset: 35
TIRES:
Brand: Nitto
Model: Ridge Grappler
Color: Agressive Orientation
Price:
$2500 total, installed
Not sure if hub centric or lug centric, I'm planning to take it to a tire shop to see if the dealer in fact put centering rings in.
FIT:
There is the slightest bit of rub on the outside rear corner of the wheel in the wheel well when turned as far as possible on flat ground. It is barely making contact with the plastic fender liner at a place where the liner is flexible and has about half an inch of flex before contacting the underlying metal. The rub is so slight that I couldn't hear it inside the vehicle and only found it on visual inspection. I think it's safe to say that this is the outer limit of size.
WHEEL IS TURNED HARD RIGHT
REAR OF FRONT RIGHT WHEEL WELL:
FRONT OF FRONT LEFT WHEEL WELL:
Thanks for the reply, I guess I will check the speedo with the stock tires and again with the bigger tires before I worry about it. Likely just going to 265/50R20. Almost an inch in height is not insignificant but if it is reading fast stock maybe it will be acceptable close with the bigger tires. Just signed on the Passport last Friday but it is still in route to the dealer.
Do you mind sharing what dealer did yours? I'm not near you but I could call them and get the scoop.
Thanks for taking the time to post this info and the nice pictures.
Discussion Starter #203
Are those Black Rhino Arches, 18x8 ET 30? They look like a darker bronze than on their website, which I like.
Not Black, I got the Gun Metal, which looks very light on the BR website, but I'm fine with them, actually happy they are not as silver looking, here is my initial thread:
