Portable Battery charger.
3333 Views 13 Replies 6 Participants Last post by  Dragon_Eyes
My wife asked me what I want for Father’s Day so I was looking at a NOCO Boost HD GB70 2000 Amp 12-Volt UltraSafe Lithium Jump Starter Box. Would that work with the Honda Passport battery? I don’t know if the Honda battery is a Standard 12 volt battery and if this would damage any electronics if for any reason my battery dies and I try to jump it. Thanks for any replies.
1 - 14 of 14 Posts
The Passport has a AGM battery and those packs work great. The lithium batteries hold a charge for a long time and a nice and compact. AGM batteries only require a battery charger that is rated for them.
Thanks, than it will work fine with the passport?
Yup and much safer then jumper cables. I have a different brand and it works great. I even purchased one for my sister who is not mechanically inclined and she has used it successfully and safely many times helping out her girlfriends.
I have a NOCO GB40 I think it is. Only car I used it on so far was a 6cyl Mercedes (twice), and it kicked it off both times instantly with ease. I just charge it every 2-3 months.
The NOCO is the real deal. We use them in the shop to jump cars all the time. I own one myself.
The 2000A is a good choice for the AGM batteries. When they discharge it takes a lot of amperage to kick the starter over again. The gear reduction starters with idle-stop need more to operate.
I live in Minnesota and the 2000A is enough to jump cars at 6am on a January morning when it's -20F outside.
TY 4 the tip.
I must ask though, what NOCO model do you recommend as this is what I ran into on Amazon.com just right now:
*This does not fit your 2020 Honda Passport
Hmmmm...
NOTE: I have zero intention of patronizing Amazon, now or ever (take a hike, Bezos). I was simply using their site for research per your referral.
Same thing happened to me. Amazon doesn’t think this is compatible with the Passport. I have also seen that if you Have to change the battery for some reason, their is a memory chip you have to plug into your PC port so it doesn’t mess the computer up. I think they run on Amazon for 12 bucks.
TY 4 the tip.
That is very similar to what we have. The only main difference between NOCO models is the amperage. I like these because they are built in idiot proof. If you hook it up backwards it will not operate. They are safer because they do not operate as a hot connection like some jumpers do. It won't power out to the battery until 1) it's hooked up correctly and 2) it senses a baseline voltage that is safe to boost. This prevents any sparks which is preferable because lead acid batteries can off-gas hydrogen and go boom. Easy enough for any wife to use too.
A couple tips:
-Even though it would be most convenient to carry this IN the car the temperature swings are too much. Keep it cool and dry somewhere.
-If it's not getting used all the time just let the charge wear down to somewhere between 20 and 80% for storage. Keeping it at 100% is going to affect the long term lifespan being a lithium battery. I charge mine once in the summer when its not being used and as much as needed in the winter.
-They sell carry cases for these if you don't want it laying around somewhere. Very handy for storage.
-These things are great if you go camping and need to charge your phone or power other USB devices.
Memory Chip link or Honda OEM part number please. TY...✌🏼
A couple tips:
Back to my original and primary question, WHAT MODEL NUMBER DO YOU HAVE?
Starting to feel this place is useless for focused AND timely feedback. Took me less than a month to figure this place out. (sigh)
Did you send him a PM (conversation)?
Perhaps he/she simply has not revisited this thread to read your posts requesting additional info.
Reactions: 2
My bad. I only check in here as time allows. This thing called life calls often.
I have the GB40 for my personal usage. We use a GB150 at the shop.
@exOC_Kook
1 - 14 of 14 Posts
