Please Post Honda Service Bulletins Here (Passport related)
25275 Views 37 Replies 9 Participants Last post by  penzance
I thought it would be nice to have a thread that collects al of the known Honda Service News Bulletins.
That way people with issues could read up on them and be more informed when they go to the dealer and not have to settle for the typical Gober Pyle answer of "Gee wiz, never heard of that happening before"...
In order to stay focused on the Service Bulletins, I'm kindly requesting that ONLY Service Bulletins (or their numbers) be posted in this thread, it's perfectly ok to add comments along with the Service Bulletin, but if you want to discuss them, please do it in another thread (or make a new thread - they are FREE!). And don't be too put off when I delete the posts from those trying to discuss the Bulletins.
Reactions: 5
21 - 38 of 38 Posts
TSB 21-012 Warranty Extension:
- 2019-2020 Passport MOST Bus Network Connectors
Same repair procedure as previous Service Bulletin 20-058 to correct issues regarding Display Audio Infotainment System:
  • Popping and Crackling Speakers
  • No Sound From Audio
  • Network Lost
This repair procedure includes extending warranty on the repair/parts to 5 years/60,000 miles.
2
Reactions: 2
TSB 21-033 Safety Recall: 2019 Passport Fuel Pump Motor
Reactions: 2
TSB 20-097 Continental Tire Recall:
- 2019-2020 Passport Sport, EX-L Trims with 245/50 R20 Continental Tires
A very limited number of 2019–20 Passports may be equipped with one or more Continental Cross
Contact LX 245/50R20 102H tires that were cured for a time beyond the specification limits. Over-cured tires may develop
a break in the sidewall resulting in sudden air loss or a belt edge separation, which could lead to a tread/belt loss.
TSB 16-054 Engine Noise after engine warms up
  • 2019 Passport models
  • Timing belt area makes a chirping noise after the engine warms up for 30 minutes
Reactions: 4
Thank you! Any way we can listen to the chirp?
If anyone purchased the running boards with lights they will install new upgraded ones for free. Honda has released a service bulletin for this product. I have only had mine on for 2 months and already 3 out of 4 lights are out. I really like going back to Honda and waiting for 2 hours for light bulbs installed.
Not actually a recall, but this and many other TSBs are listed by in another post. TSB 20-022
Don't know how @P-A-N-D-A gets all that inside info, but glad the bear shares them here.
MOST Bus Network:
Overview, Troubleshooting, and Repairs
Honda Tech2Tech Notes on how to Troubleshoot/Repair Display Audio MOST system
Reactions: 4
Honda ServiceNews September 2021
Only use Genuine Honda Brake Fluid
:rolleyes:
TSB 22-027 "No Audio Connection" Message
This directs Honda service to replace the stereo amplifier if the MOST connectors are not the source of problem.
2019-2020 Passport
TSB 20-056 "MIL Comes On with DTC P2422"
2019 - 2022 Passport Emission Fault
Check Engine Light, EVAP canister vent shut valve stuck closed malfunction
Reactions: 2
TSB A22-032 "Product Update: Blower Motor Inspection"
Service Bulletin for Blower Motor Inspection for manufacturing defect that may cause the motor to overheat.
Affected vehicles - 2022 Passport, 2022 Pilot, 2022 Ridgeline. Specific VINs apply, check for eligibility at the dealer.
TSB 23-008 Product Update: PGM-FI Idle Stop Software Update (2019-2022)
BACKGROUND
Under certain circumstances, after coming to a stop and the idle stop feature engages, the vehicle may not automatically restart. Typically, the customer can immediately restart the vehicle by selecting Park and pushing the ENGINE START/STOP button.
CUSTOMER NOTIFICATION
Owners of affected vehicles will be sent a notification of this product update. Do an iN VIN status inquiry to verify eligibility. Some vehicles affected by this campaign may be in your new or used vehicle inventory. Repair these vehicles before they are sold.
CORRECTIVE ACTION
Update the PGM-FI Software. NOTE: The software update will decrease the Idle Stop operating range. As a result, the customer may notice reduced idle stop engagement when their vehicle’s battery is approaching the end of its useful life.
TSB 23-010 Warranty Extension: Engine Does Not Auto Restart After Entering Auto Idle Stop (2021-2022)
BACKGROUND
Under certain circumstances, after coming to a stop and engaging idle stop, the vehicle may not restart automatically due to excessive cylinder pressure and/or low cranking torque. Typically, the customer can immediately restart the vehicle by selecting Park and pressing the ENGINE START/STOP button. NOTE: If 23-008 Product Update: PGM-FI Idle Stop Software Update is applicable to the VIN, the PGM-FI software must be updated first before the warranty extension applies. Honda is extending the warranty coverage for valve adjustment to 10 years from the original date of purchase with no mileage limitation.
Owners of affected vehicles will be sent a notification of this campaign. Do an iN VIN status inquiry to verify eligibility.
CORRECTIVE ACTION
Adjust the valves.
  • Helpful
Reactions: 5
Owners of 2021-2022 Passports also receive extended warranty coverage for valve adjustment to 10 years from the original date of purchase with no mileage limitation.
Owners of 2019-2020 Passports receive Honda's extended "Go Pound Sand" warranty.
At least there is something useful for D-I-Y mechanics included in the A23-010 Service Bulletin.
Detailed instructions on how to complete valve adjustment on our 3.5 engine.
EDIT: 3/3/2023
23-009 Starter & Valve Adjustment Warranty Extension for 10 years
2019-2020 Passports that received 23-008 Software Update
It is dated Jan. 6, 2023. Has anyone with 2019/2020 Passport received this warranty extension notice.
I printed it out and put it in my Passport paperwork in case Honda service develops amnesia about this 7 years from now.
Reactions: 3
Self deleted for bulletins only.
TSB 23-024 Headlight Moisture
2019 - 2023 Passport
Special Thanks to Mt.Man for posting this in another thread
TSB 23-023 Moisture Inside Starter
The engine will not crank on initial startup after precipitation and sub-freezing temperatures
TSB 23-035. Safety Recall
2020 - 2022 Passport --- Exterior Mirror Glass
Thanks to Mt.Man for posting this info in a different thread.
21 - 38 of 38 Posts
