41 - 59 of 59 Posts
My bad I guess I did it ask the proper question. The stock tpms sensors from the ridge line is what I’m wondering if they would work
I believe YES. The part number for Passport vs Ridgeline is different, but probably the same. Tire Rack lists the same TPMS part number for both.
  • Passport P/N: 42753-T6N-E02 (TPMS kit)
  • Ridgeline P/N: 42753-T6N-A01 (TPMS kit)
  • Same for both TMPS (433MHz) P/N: 42753-TG7-A51
Fact? Fiction? ¯\_(ツ)_/¯
Could you explain what brand/manufacturer and part/model # “sport edition” wheels are? Your 2016 what? How much clearance from caliper to the 17” rim? Thanks.
Likely one of these from Tire Rack. Sport Edition is Tire Rack's house brand.
Tire Rack site states these 11 styles/sizes of their "Sport Edition" wheels in the link above will fit 2019/2020 Passport.
Ok so I picked up a set of 2017 ridge line rims with stock tpms sensors. I had blizzard mounted and tested them out. The tpms sensors were read by the 2020 passport so all is great. Thanks for your help
2019 Honda Passport Elite
Looking at these for my 2019 PP Elite w/ 245/60-18 tires; says the size fits the 2019 Ridgeline with the installation kit that fills the gap in the hub...size is 18" x 8", +35 Offset, 5x120.65 Bolt Pattern, 74.1mm Hub. I'm thinking they'll do nicely...just a little grey accent with all that black. Anyone see any size or clearance issues with these?
5833
I assume the "installation kit that fills the gap in the hub" is something like this?
If they don't include hubcentric rings, buy 'em -- they are inexpensive and virtually eliminate many complaints regarding vibration with aftermarket wheels.
· Super Moderator
Has anyone had any luck adding wheel spacers? I actually like the stock Sport wheels but I’m looking to change out to wider tires and want a little more stance. Should I just go with aftermarket wheels?
By wheel spacers, do you mean hubcentric rings?
If so, I had them put on. I didn’t notice a difference in the short distances I did drive with the wider tires without them, but my Honda shop suggested I put them on. Had the tire shop order them and they were installed a few days later.
btw - nothing I dreaded more about my Passport than looking at the black gloss OEM wheels for the 7 months I had them!
6373
Hi everyone, I'm thinking about picking up a set of 18'' wheels off a 2020 Ridgeline. I see a lot of discussion on fitting oversized tires, but looks like most are being installed on a wider offset than OEM 55mm. Can anyone tell me:
  • What are the tallest tires I can fit on the 18'' OEM wheels?
Thanks -Michael
Can the Touring/Elite 265/45 R20 tires/wheels mount onto an EX-L PP without any needed adjustments? Thanks.
They will bolt right on, no problem.
You will be fine to run them on the 8.5” rim.
Reactions: stuman74
41 - 59 of 59 Posts
