1 - 20 of 59 Posts
Bolt pattern: 5 x 120mm
Offset: +55mm
Hub diameter: 64.1 mm
Wheel size (Touring, Elite): 20 x 8.5 inches
Wheel size (Sport, EX-L ): 20 x 8 inches
Tire size (Touring, Elite): 265/45 R20
Tire size (Sport, EX-L): 245/50 R20
2019 Passport Elite Wheel
2019 Passport Touring Wheel
2019 Passport EX-L Wheel
2019 Passport Sport Wheel
Does anyone know the weights? Wheel, tire and/or both combined (lbs. per corner).
Thanks.
Alternative OEM wheel and tire size to maintain similar dimensions and ride height, below. Use a Tire Calculator to confirm dimension differences and effect on speedometer.
Passport:
  • Tire 265/45R20 (Wheel 20x8.5J ; Offset 55) = Circumference 92.3" = Diameter 29.4"
  • Tire 245/50R20 (Wheel 20x8J ; Offset 55) = Circumference 93.1" = Diameter 29.6"
Pilot / Ridgeline:
  • Tire 245/55R19 (Wheel 19x8J ; Offset 55) = Circumference 93" = Diamter 29.6"
  • Tire 245/60R18 (Wheel 18x8J ; Offset 55) = Circumference 92.9" = Diameter 29.6"
If you wish to maintain the same bolt pattern, offset and hub diameter (see post #1), you will likely have to use a Honda or Acura wheel.
18" may be the smallest wheel that will clear the brake calipers? It would be good if someone confirms.
If you search the internet (Craigslist, Facebook Marketplace, eBay, etc), it is possible to find used Honda or Acura wheel sets that fit. I have found a set of 18" wheels from a Ridgeline that I will re-purpose for winter duty.
Example of tire size comparison:
Tire Automotive tire Wheel Product Rim
Nice, let us know please. I can’t handle 20’s. Typically they ride like crap, and to me, old timer look dumb. Also Chicago streets eat up 20”rims
Just returned with my acquisition. From a 2018 Ridgeline (higher level trim)... 18x8J & Offset 55. I'm certain they fit. Will not be installing till the fall with winter tires. All 4 wheels were "like new" condition. :love:
Alloy wheel Rim Wheel Auto part Spoke
Cool, so what size tires do you plan to put on these rims?
Unconfirmed, but the Elite tire/wheel set-up is approximately 64 lbs. per corner.
Does anyone know if Acura rims will fit right on?
You can verify the spec of another vehicle's wheel on the internet like this. This is for a 2017 Acura MDX that would be compatible.
Text Font Line Number Screenshot
Some wheels will fit and you will have to check/verify the spec...
  • Bolt pattern: 5 x 120mm ... If different, it will not match up to the Passport wheel lugs.
  • Offset: +55mm ... If you wish to match the same factory offset for the Passport.
  • Hub diameter (Center Bore): 64.1 mm ... If smaller, it will not fit the passport. If larger, it will require a centering ring.
  • Wheel Size: 18" diameter or higher will work. There may not be sufficient clearance for the brake calipers with 17". Width will vary based on wheel diameter and tire size to be mounted.
Physical verification on the backside of the wheel spoke, some specs are stamped into the casting. "18x8J 55"... 18" wheel, 8" width, "J" type lip, +55 offset.
Alloy wheel Wheel Tire Rim Automotive tire
I know it's a long way off, but when you get these mounted, please post an update and pictures. Thinking of doing the same thing when the original set of tires are ready to be replaced, so very curious to hear how you make out with this. Thank you for all the info in this thread.
Yes, will do. The Ridgeline wheels (same offset, bolt pattern, hub diameter) and 245/60R18 tires (nearly same tire diameter) should work without a problem. The Ridgeline and Passport are built on the same platform and share many of the same components.
Agreed, I have a 2017 Ridgeline and it's remarkable how similar these vehicles are.
Any update with putting 18" wheels on? Does it offer a smoother ride?
I have Elite with 2k miles and HATE HATE the amount of feedback coming thru steering wheel, even on smooth roads in Florida. To the point where I'm considering trading in and taking the loss. Otherwise I love the vehicle, and if 18" wheels smooth things out then would be happy to pay to swap.
I'm expecting to have a set of 18" wheels on the Passport in the next 1-2 weeks, and will report back when done. I'm not expecting it to make a difference in ride quality. Can you give some details about the issue with steering wheel feedback?
1 - 20 of 59 Posts
