It's for the OEM hitch installation. Just figured some might be interested in seeing the Passport without its bumper.Why?
The OEM hitch replaces the bottom plastic trim with one with a cutout. I had to remove the bumper to swap that trim piece. Other than that, the hitch goes on with 6 bolts, just like other hitches. I guess the only difference is the OEM hitch doesn't compromise ground clearance from the rear.I was under the impression that the OEM hitch could be installed without removing anything. It just bolts from underneath.
Well you had better move the exhaust pipes too then, my receiver hitch is tight up against the bottom of the bumper is even across the bottom of the pipes. so if it hits it won't hurt it but you will fixing exhaust pipes....lol...The OEM hitch replaces the bottom plastic trim with one with a cutout. I had to remove the bumper to swap that trim piece. Other than that, the hitch goes on with 6 bolts, just like other hitches. I guess the only difference is the OEM hitch doesn't compromise ground clearence from the rear.
It can, I did it about 30-40 min, hitch and new panelI was under the impression that the OEM hitch could be installed without removing anything. It just bolts from underneath.
Yeah, but then you can't suck us all into reading your post by putting "nude" in the subject line...![]()
No need for measurements. Mock up your bumper and mounting plates. Bolt on mounting plates and tack weld your bumper to them.I'd love to get the measurements for those mounting brackets. I have a pipe dream of designing a custom steel bumper that incorporates a swing out tailgate / spare tire holder!
Agree but not super repeatable if I wanted to design something that others might enjoy too 😂😁🤔No need for measurements. Mock up your bumper and mounting plates. Bolt on mounting plates and tack weld your bumper to them.
Un bolt and finish her up. Easy peasy.
Well, once you build your prototype, you can get all the exact measurements you want.Agree but not super repeatable if I wanted to design something that others might enjoy too 😂😁🤔
Very trueWe
More than one way to skin a cat.
Can't wait to see what you end up building!
Not a sensor.Can anyone tell me what the sensor is I have circled in the picture?
Thank you, I'm rebuilding a wreck I bought at an insurance auction, and it was in the pile of parts removed from the vehicle. I had no idea what it was. Now I just need to figure out a part number for it and is name Honda calls it.Not a sensor.
It is the acoustic device that makes the loud 'beeping' warning sound as the lift gate opens and closes.
Same here. My large glove size hands took about 45 min of me lying on the ground/sitting up to install new valence and tq receiver to chassis.It can, I did it about 30-40 min, hitch and new panel
