Here is the maintenance schedule for the maintenance minder.
Honda Maintenance
A Replace Engine Oil
B Replace engine oil*1 and oil filter
● Inspect front and rear brakes
● Check parking brake adjustment
● Inspect tie rod ends, steering gearbox, and boots
● Inspect suspension components
● Inspect driveshaft boots
● Inspect brake hoses and lines (Including ABS/VSA®)
● Inspect all fluid levels and condition of fluids
● Inspect exhaust system#
● Inspect fuel lines and connections#
CODES
1 ● Rotate tires
2 ● Replace air cleaner element
Replace dust and pollen filter*3
● Inspect drive belt
3 ● Replace transmission fluid and transfer fluid*
4 ● Replace spark pugs
● Replace timing belt and inspect water pump*4
● Inspect valve clearance
5 ● Replace engine coolant
6 ● Replace rear differential fluid*
7 ● Replace brake fluid
