1 - 4 of 4 Posts
4 months and 8,500 miles since oil change #1, Mobil synthetic 0W-20, Fram premium filter XG7317, 5.7 qts. Plastic around the filter that I cut out last time made this change even easier. Maintenance minder told me 15% oil life remained. Oil looked dirtier than the change at 4400 miles.
Going to change the air filter this week, rotate tires when I take it in to have dealer change transfer case oil in a couple thousand miles.
Do you mean differential case instead of transfer case? The differential code "6" is usually around 15000 miles, then every 30000 miles. The transfer case is code "3" and usually around 60000 miles along with the transmission fluid from what I have read regarding the Maintenance Minder system on these and my 2019 Pilot AWD..
The differential also calls for DPSF-II (DPF-II is the same) and is even marked on the differential case by the fill plug.
Yes, thanks for setting me straight.
Took our Elite Silver Lunar Metallic in for its first oil and oil filter change and tire rotation at 6,400 miles. It might just be my imagination but on the way home, it seemed to run quieter and shift smoother.
1 - 4 of 4 Posts
