OEM crossbar length
2296 Views 15 Replies 4 Participants Last post by  carpayments4life
Anyone with OEM crossbars, can you share the length of them? I'm looking at a rail change. Many thanks.
1 - 16 of 16 Posts
The total length of the bars end to end is 43 9/16" and the measurement between the rails is 43 3/16"
That's weird, tried edit reply and it didn't save it. Hopefully this doesn't pop up twice later.
At any rate, the crossbar length is about dead on what I need for my existing rack.
Can anyone tell me the gap measured between the inward points of the front/rear rail mount? Here's a pic, it's a bit vague to describe in words:
Vehicle Automotive tail & brake light Hood Automotive lighting Motor vehicle
The measurement you requested is 49 3/16"
The measurement between the rear & center bracket is 24 1/2"
The measurement between the center & front bracket is 17 13/16"
Car Vehicle Motor vehicle Hood Automotive design
Oh wow, so the whole gap between front and rear brackets is less than 48"?
This may actually work...I need 49" of clearance on the rail.
Rectangle Wood Storm drain Tableware Manhole
I' ve got a frontrunner rack from an old jeep of mine. I'll keep you posted and many thanks for the help.
You've been a huge help here JLH! Greatly appreciated.
Now, I'm pretty sure I won't have tailgate clearance issues....but better to be on the safe side. What's the clearance from off the front of rear rail mount to the tailgate opened?
If my math is right I'll need 10 1/4" inches to clear. It will be riding above the rail a couple inches for sure, but the baseline will give me a worst case scenario. I showed it on yours here closed:
Car Vehicle Motor vehicle Hood Light
Hey thro1 that dimension is 17" (front of rear rail to hatch - being open and at the center-line right behind the shark fin .
Nope,
I got 49 3/16". I can double check for you but am away from it till this evening.
With the tailgate open, I get 17 3/4" at the base of the rail support to the bottom leading edge of the tailgate.
Looks like I'll be able to do this, I'll post some pics when it happens. Thanks again all.
I'd love to see pics once you get it done!
2
@JLH Worked out pretty good my friend. Thanks for your help!
Hood Automotive carrying rack Car Lighting Automotive exterior
Car Automotive carrying rack Vehicle Window Light
That looks great! Glad I could help.
That rack looks huge and looks noisy, because the flat "leading" edge is in front of your sun roof.
When not using the rack, the front cross arm should be slid back, about 14" behind the back edge of the sunroof, to reduce wind noise in the cabin. Your sweet spot, for noise reduction (with no rack) may vary.
I believe someone on this forum has figured out an ideal distance, otherwise, those flat surfaces make the Passport look rugged.
1 - 16 of 16 Posts
