Any solution been found for this? Interested in getting skid plates but don’t want noises
Since the function of a skidplate is for undercarriage protection, but not to increase chassis rigidity, your trial changes (remove/reinstall) demonstrate that the noise is likely due to the flexing of the skidplate metal itself.1) It’s 100% definitely the skid plate that makes my popping in parking lots. I’ve taken the skid plate off more than one time to test the theory, and every time it only pops with the skid plate on.
2) The U-bolt kit was a must for mine, as with the standard hardware kit they send with the 4 bolts in the front, I couldn’t eliminate the popping sound for the life of me no matter how tight I went. And because those 4 bolts are little 10mm and weaker, one of them I snapped clean off. U-bolt kit has allowed me to tighten it way tighter.
3) My local dealership has no idea how to remove and reinstall aftermarket skid plates on the Passport. They took it off for an oil change and put it back on, cross threading one of the rear bolts which is now permanently screwed and only goes in at an angle. I change my own oil now… with the skid plate on.
I believe that your suggestion will make the situation worst. Tightening the bolts eliminates the creaks (per @REALM) which is opposite to your suggestion. The two rear bolt locations secures an existing structural member to the frame. With a skidplate installed and securely bolted (direct connection, solid metal spacers in my case), it further increases front structural rigidity. I notice a difference in structural rigidity handling with and without a skidplate installed.Since the function of a skidplate is for undercarriage protection, but not to increase chassis rigidity, your trial changes (remove/reinstall) demonstrate that the noise is likely due to the flexing of the skidplate metal itself.
Perhaps consider further isolating the skidplate instead of tightening it up, so that the skid plate is allowed to slightly shift position instead of forcing it to flex??
Instead of direct bolt-to-skidplate-to-chassis connections, makes me wonder if enlarging to bolt hole in the skid plate and installing a grommet style washer into the enlarged hole might reduce or solve the issue. That may allow skidplate to slightly flex, but isolate it from the chassis enough to reduce noise transfer.
Skidplate would still be secure, just now it could allow some movement without binding.
I have the JSport, but I believe that NO-LO install is similar. So, similar issues unless you have rigid connections and torque the bolts tight.Anyone experience this with the JSPORTUSA Front Skid?
So are you experiencing these issues?I have the JSport, but I believe that NO-LO install is similar. So, similar issues unless you have rigid connections and torque the bolts tight.
The original hardware that came with my skid plate did not have solid spacers for the rear. See one of my previous post on how I added fender washers and a nut as a spacer. Since doing so, my skid plate does not creak or pop.So are you experiencing these issues?
Yes Ian changed out the nylon spacers for aluminum ones provided in the recent kits.At the time when I purchased my skid plate, it came with two nylon spacers for the rear. I reached out to no- Lo and stated to remove the nylon spacers. I did that about a week ago and thus far no noise. 🤞
Dang, I'm on his emailing list. I get the emails on the raffle tickets, which I participate in, due to a good cause, but no update on known product issues and fixes. Maybe he could sponsor someone here and they could keep us update with product development. 🤷♂️Yes Ian changed out the nylon spacers for aluminum ones provided in the recent kits.
