1 - 11 of 11 Posts
2020 Honda Passport Sport
Here is a picture of the layout I use to monitor my engine and transmission vitals. I am still on the hunt for the correct PID for the app to show me engine oil temp, but I'm not sure if our vehicles have a way of measuring it from the factory.
I can run a scan for any codes and can reset them if applicable. The Torque Pro app has not given me any problems so far on my KTunerFlash 2018 CRV and my Passport now.
You peaked my interest with this posting. Now i have to go and find out more about Torque Pro....
I didn't have any luck finding the coolant/engine temp or the oil pressure with Torq Pro.
Discussion Starter · #6 ·
Should be included by default. Here are 2 screenshots of the pids for engine coolant and trans temp.I'm running a paid version of torque pro so I'm not sure if these two pids are available in the free version. I'm in Canada so my values will be in celsius.
Both numbers I know are correct as I have an s-vcm tuner installed and both my engine coolant and trans temp are reading 10c below what I had before the install.
Regards
Regards
Thanks! I just ordered the OBDII dongle and plan to use Torque Pro. I basically want to see the transmission temp while towing. I have a 2020 Passport and had the ATF cooler installed when I bought the vehicle.
@YVRPassport , hey could you give the PID information of the eng coolant temp 0167. I have the transTemp now! Thanks
2022 Passport AWD
Is 'fe1805' the PID that I would enter in the Torque app to get the trans temp to show? And '0167' for engine coolant temp? Looks like I can potentially screw things up with the ECU if the wrong inputs are entered??
1 - 11 of 11 Posts
