21 - 33 of 33 Posts
Hi @Moab Junky, would you start a new thread for suggested off-road routes that easily suits the Passport in Moab? Can any of these routes be done alone or best to have a wingman? We periodically pass through the area and love the geology of the area. Thanks.
Discussion Starter · #23 · (Edited)
I finally got around to building my spare carrier.
I started with an old piece of 3/16" steel.
Wood stain Tan Plywood Paint
I cut it out with my grinder. I put a cut off disc on it. Anyone can do this.
Metalworking Machine Tool Service Grinding
Hoisted the wheel up to make marking the holes easier.
Automotive tire Iron Automotive wheel system Spoke Machine
I had some 1/2" bolts on hand.
Tool Iron Machine Drill Power tool
Bolts welded in place.
Tool Iron Tool accessory Steel Metalworking hand tool
Alloy wheel Machine Rim Automotive wheel system Nail
Discussion Starter · #24 · (Edited)
Shelf Bicycle frame Shelving Box Collection
Personal protective equipment Headgear Helmet Door Shelf
Tire Automotive tail & brake light Automotive tire Vehicle Automotive exterior
Tire Wheel Motor vehicle Automotive tire Automotive tail & brake light
I left the donut in the back. We will only slide this baby into the hitch when we go out of town.
Its super easy sliding the whole thing out.
The 2x2" steel is only 1/8" thick, so it's not all that heavy, but plenty strong.
Discussion Starter · #25 ·
So today, we went for a Sunday drive out to the desert to visit our dear old Yellow Labs grave site.
I decided to test the Passport out on some really steep, loose hills.
HOLY COW!!!
The electronic traction control features in this AWD are amazing.
The pictures do not do the size or steepness of these hills justice, but I'm here to tell you, this thing was very impressive.
I didn't speed up any of these hills, just crawled them in first gear.
I am loving these Hankook Dynapro tires. We did not air down.
Mountainous landforms Slope Landscape Hill Soil
I did get the tires to break loose climbing up the face of the hill in the above photo.
Crawling up the backbone on the harder trail was effortless. No spinning, and again, much steeper than it looks.
Landscape Soil Terrain Automotive exterior Slope
Brown Mountainous landforms Landscape Slope Hill
Approach angle isn't bad, departure is a bit better. Breakover is ok, but is the lesser of the three.
Here our muffler is touching the hill.
Tire Wheel Automotive tire Automotive design Natural environment
Tire Wheel Automotive tire Automotive design Vehicle
Overall, I was quite impressed. We never did touch the front or rear bumpers on the ground.
Discussion Starter · #26 · (Edited)
This is a little oval track that we would race the dirt bikes around. This thing was fun to push through the corners and rhythm sections.
Automotive design Landscape Soil Automotive exterior Off-roading
Soil Landscape Plain Ecoregion Terrain
Tire Wheel Automotive tire Automotive design Automotive tail & brake light
Discussion Starter · #27 · (Edited)
I'm not sure why, but I really dislike Chrome.
I used black Plasti Dip to black out my rear badges.
Tire Product Motor vehicle Automotive design Wheel
For those of you who haven't used this stuff, it is mostly rubber, dries firm, but not hard,, non tacky, and with a little effort, can be removed years later.
You can paint it for added toughness and color.
It actually protects the paint or badges that you apply it to from road salt, mag chloride and UV rays.
This Ford emblem was sprayed several years ago. It used to be blue. The Plasti Dip gets into the finest cracks. Pretty cool.
Hood Automotive lighting Automotive design Headlamp Vehicle door
You don't have to mask off the whole car. This stuff is real heavy and doesn't travel through the air as easily as paint does. If you wax your car before hand, it peels off much easier. Just clean the badges really well prior to spraying them with the dip.
A clean soft rag will remove overspray.
I masked it off like this. Pull the tape off carefully, down and away from the letters.
Hood Automotive lighting Automotive tire Motor vehicle Automotive design
And then gently peel away from the letters like ths.
Hand Hood Automotive lighting Automotive tire Motor vehicle
A wooden toothpick is needed to remove the dip from the center of the letters. It won't scratch your paint.. Pulling down and away from the letters.. (You can leave those centers black if you wish) I picked mine out.
Reactions: DudeCS
Do you mind sharing the dimensions of your construction so we may decide to build our own? I like the simplicity of it.
Discussion Starter · #31 ·
Here you go.
The design and materials are super strong.
Often times, when I build something, either out of wood or steel, I find myself beefing it up way beyond what is necessary.
Engineers on the other hand, have attended years of specialized schooling, and have access to lots of programs, data and testing results, which helps them design things that are just strong enough to meet the demands they will face. This knowledge saves them money by not
over-engineering things and keeps them from wasting time and materials.
The tubing is all 1/8" thick.
The plate is 3/16" thick.
It's not too heavy. If I built this again, I wouldn't change a thing.
Obviously not drawn to scale.
Handwriting Rectangle Parallel Font Slope
Now, I left the 17 1/4" piece long for a reason.
Almost everything you slide into your hitch will rock back and forth. I may use the that part for added stability. It protrudes well beyond the hitch sleeve.
I have made and used steel shims to help eliminate wobble in the past with fairly good results.
I know there are special hitch pins that can be used as well.
Let me know if you if you need anything else.
Reactions: Cilles
Here you go.
Thanks! Looks pretty simple indeed. But I do have a few questions.
What about the face plate itself. Those bolts need to be kind of precisely placed in order to fit onto wheel. I guess just measure them for my specific wheel, correct? Though all passports should have same lug spacing unless you did something really weird.
And any reason you made the plate stop sign shaped? Just to round off the corners without going fully round? I'm thinking triangle, or if I got lucky and found round steel plate right size, would do as well and maybe be easier to cut out. Maybe not.
Oh I see some construction pics above that I missed first time. That helps.
Discussion Starter · #33 ·
I don't have a plasma cutter. So octagon was easy to cut, and more stable than a triangle.
I just traced 3 lug holes right onto the octagon, then drilled them out. Fit was perfect.
Reactions: Cilles
21 - 33 of 33 Posts
