I know no one probably knows quite yet, but wanting to lower my passport some. Curious if the MDX springs will work since it shares the same platform as the pilot which the passport is based off of.
And yet at the LA auto show they claimed it was to have 8.4 inches of ground clearance, and yet it only has 8.1. Only .8 more than Pilot. So Honda messed something up. So much for having that so calledBasically for a cleaner look, trying to retain to great ride quality though since it’s my wives daily. Fuel economy should increase since Honda’s reasoning that it was lower was due to the increased ride height.
Did you ever install the springs? I’m interested in lowering mine as wellBasically for a cleaner look, trying to retain to great ride quality though since it’s my wives daily. Fuel economy should increase since Honda’s reasoning that it was lower was due to the increased ride height.
I just lowered my 2020 Passport Elite using RS-R lowering springs that were meant for the 2020 MDX. Not aggressive, clean and very driveable.I know no one probably knows quite yet, but wanting to lower my passport some. Curious if the MDX springs will work since it shares the same platform as the pilot which the passport is based off of.
I just lowered my 2020 Passport Elite using RS-R lowering springs that were meant for the 2020 MDX. Not aggressive, clean and very driveable. View attachment 8034
If you want one of a kind, I say go big or go home. 😁I am going to lower mine once a wrap it. I personally like my vehicle to be one of a kind .
did you have to change the shock absorbers or put in a camber kit ?
. How much of a drop did you getView attachment 8448 factory shocks, no camber kit. The front is fine, but the rear does have a negative camber. Looking into correcting that soon.
