Maintenance Minder web site with code meanings and recommendations.
1094 Views 14 Replies 6 Participants Last post by  ballisticexchris
This web site explains what each code means. I thought it was a quick go to when you have a code pop up on your display!
Reactions: 3
1 - 15 of 15 Posts
Pretty cool info for the average owner with no mechanical skills. I personally performed beyond both "A" and "B" at 500 miles and again at 2,000 miles when I installed my ValvoMax quick valve.
In addition to the following "B" service every 3,000 to 5,000 miles (5,000 max between oil change if I'm highway driving):
Replace engine oil and oil filter.
Inspect Brakes & All Brake Hoses & Lines
Inspect Suspension Components & Tie Rod Ends
Check Internal & External Lamps & Exhaust
Inspect Gear Box & CV Boots
I also go front to rear/inside and out/top to bottom and under the hood check every single part I can lay my hands on. I get an inspection light and do a visual checking for leaks both fuel and oil. I addition I rotate wheels at each oil change. Once I have had this vehicle for a while I'll be able to tell what items require more attention.
A common issue I can already see that's Passport specific are the knuckles. They are bare and prone to rust. I live in Southern CA so I will wait until first brake service and paint them. For those in the rust belt I recommend painting them ASAP.
At 7K I'll do the diff and transfer case then service every 3rd to 4th oil change.
Biannual/30K (whichever comes first) brake/trans fluid and coolant servicing
Brakes are replaced when they are at 25%. I fully disassemble and clean/lube caliper pins (with Permatex Ceramic Extreme lube) and replace all springs.
60K-75K I will R&R timing/serpentine belt, water pump, pulleys, hydraulic tensioner, adjust valves and replace plugs
These are just basic simple tasks that anyone with basic mechanical skills can do on the cheap. For anything beyond I will have the dealership or trusted mechanic do.
Only I set the mileage as to which the service is required. The only time the dealer will touch my vehicle for routine service will be the upcoming free first complementary rotation of wheels and "B" service. This will be at about 5,000 miles.
I do not care a whit about how good oil is or what an oil analysis tells me. Going beyond 5,000 miles between oil changes on any direct injection motor is asking for trouble. You might not see it during the warranty. However if you plan on keeping it for 300,000 miles and beyond or selling it to a private party to enjoy, then being maintenance intensive is a good thing. Not to mention cheap and easy.
The Owners Manuel does a good job of explaining the MM system and what the codes mean.
Font Material property Document Number Paper product
If you follow the MM and do the indicated service(s) properly on time, every time you should not have any issues with the vehicle in the short term or the long term. Keep in mind that Honda, as do all of the other manufacturers have a host of 46 or more differently trained and specialized engineers to design and test every component for each and every model vehicle. No one knows more about the vehicles that Honda or any other manufacturer puts out than the engineers that designed the vehicle.
Reactions: 2
Tell that to the owners with the vehicle4s down time and mechanics that have to repair these vehicles prematurely due to lengthened service intervals. It is important to remember that it is not only engineers but bean counters and the EPA that have a say in estimated longevity.
It's the 21st century now, you might want to join it.
Amazing that so many have the same recommendation. Follow what the manufacturer indicates in the owners manual.
  • Haha
Are you trying to make @ballisticexchris throw a fit or what? :)
  • Haha
Reactions: 3
If someone wants to follow their own schedule that's fine, its on them, however the manufactures do the designing, and testing of their vehicles so they are quiet aware of exactly what is used in the ways of materials both in the vehicles and in the lubricants/fluids they recommend.
The universal pushing of outdated ideas and standards is to me akin to having a dealership, quick lube shop, or independent mechanic pushing uncalled for add on services. Unless called for by a particular individuals driving habits or environment, following overly zealous change intervals, is wasteful both monetarily as well as in resources with no proven value to the longevity or reliability of the vehicle.
Anyone who owns a vehicle should have a basic understanding of their driving habits and follow basic maintenance practices, such as pulling a dip stick once a month to check the oil level, transmission fluid level if possible, opening the brake fluid reservoir for fluid level, power steering pump reservoir for fluid level and checking the level of their coolant, as well as checking tire pressure.
  • Haha
Reactions: 2
I can just imagine the vein on @ballisticexchris’s forehead pulsing 😂😂😂
  • Haha
Reactions: 2
First someone opens a can of worms then someone is ready to open a can of ass whuppin 🤣🤣🤣🤣🤣
Honesty, I thought this thread was opened just to add fuel to the fire - of the other thread.
To be honest, 99% of the Honda owners are gonna drive until MM tells them to service the vehicle sometimes beyond. If MM is wrong, we will be seeing massive issues with Hondas.
LOL, does not bother me a bit what someone else wants to do in regards to maintenance. I'm merely letting owners know the detrimental effects of poor maintenance.
BTW, the snide comments I can do without. This is an adult forum and expect members to act as such. You may disagree. However, baiting members with adolescent comments serves no purpose.
I don't know if your comment is directed at me but I had no intention of being snide, just highlighting the fact that you are passionate about the topic. However, if my comment annoyed you please accept my apologies.
With that said, you have to admit that you belabor some topics much too much and you tend to make some rather extreme claims like the one below 👇
The misinformation spread on this forum can result in negative consequences to the owner. Especially for those that plan on keeping their vehicles for 15+ years and 300K plus miles.
Reactions: 2
As for me it was all in fun and a laugh. Much respect to your passionate post brother!
I don't know if your comment is directed at me but I had no intention of being snide just highlighting the fact that you are passionate about the topic. However, if my comment annoyed you please accept my apologies.
With that said you have to admit that you belabor some topics much too much and you tend to make some rather extreme claims like the one below 👇
Fair deal. I would not call my claims extreme by any stretch. But alas, yes I have been a bit argumentative with the community lately. For that I apologize as well.
1 - 15 of 15 Posts
