1 - 9 of 9 Posts
2022 Passport AWD
I was flipping through the maintenance menu checking tire pressures when I saw the B in the oil life screen. I've got 80% life left. 9,300 miles total. The oil & filter were changed and tires rotated at just over 8,000 miles roughly 2 1/2 months ago.
Why would I be seeing a service code now? Is it a reminder to check brakes?? I'm not finding anything specific beyond oil, filter, rotation...
2022 Passport AWD
The maintenance code is to remind you what’s coming up not what needs to be done right away. Just keep driving until less than 10%. There will be more codes coming up as you get near the end.
And for the meanings of the codes.
OK, I don't remember A showing up this early. So as it gets closer to the actual time to perform the service there'll be numbers with the B? Thanks 👍
1 - 9 of 9 Posts
