Here is a bit of advice for all of us. As a former ASE certified mech years gone by, it was always a given to change your oil after a break in period of 2-3k miles. This allowed for metal shavings from just break in. deposited in the filter system to be removed, any lowered viscosity in the engine oil as parts settled in and to refresh the oil system with virgin oil. In todays climate we have so many sensors involved in the cooling of not only the engine oil but also the transmission temp, I wouldn't be surprised you have triggered a sensor which could be to a number of controlled areas and the car has determined "svc oil needed" sure the oil life is based on millage and use. Oher engine sensors are based on Oil pressure and oil temp. That notion, change oil at 3k was bumped by the consumers and moved back to 5k intervals. I would be going to the dealer and getting an oil change, I would be freaking out it could be a collapsed or plugged oil filter which can and will damage the engine if not changed. r
