I replaced all interior lights with LEDs. Wondering if the LED backup light gives you a brighter, better view in the backup camera? Thanks
Bulbs - https://www.amazon.com/dp/B01H57FXWA?ref=ppx_pop_mob_ap_shareThat’s cool. Do you have a link to the bulbs you used? And the install is easy?
The link to the LUYED bulbs posted by FourCorners are the exact same bulbs I installed on my Passport in March.Can anyone confirm if either of the bulbs mentioned by @FourCorners or @F1Flagger will work for a 2020 Elite? Amazon is telling me that neither of these fit my 2020 Passport(?):
That is my 2020 Passport Touring that they are inHere is what I used;
JDM ASTAR Extremely Bright 144-EX Chipsets 7440 7441 7443 7444 992 White LED Bulbs with Projector For Backup Reverse Lights Amazon.com: JDM ASTAR Extremely Bright 144-EX Chipsets 7440 7441 7443 7444 992 White LED Bulbs with Projector For Backup Reverse Lights: Automotive
The photo below is from video drive way camera last night. You can see how bright they are
Good guess but no. I ordered D15 LED backup lights for my Elite on Amazon and it reported that they fit and no warning messages. Hope this helps.I'm going to guess that Amazon is going to say that anything other than incandescent replacement bulbs is not the right ”fit.” You're probably not supposed to use LED bulbs, but a lot of people have, and they seem to have been successful.
Thanks for the quick response. I changed all interior lights. It's was pretty easy and simple although the door lense seem to pop off much easier with gentle pressure with a small screwdriver instead of the plastic tools (the tips bend). My only struggle was with the glovebox. I didn't want to pop off trim so I tried disconnecting the cable and lowering the box but still couldn't reach in that hole with fingers. Does anyone know of a tool that can reach in the hole then remove and reinstall the new bulb? Thanks again! BTW, the LEDs have a nice look to them. I'm looking forward to changing the backup lights when they come.Yeah Amazon has a warning message on incompatibility but in this case I believe it is an error. Actually when I bought them there was no fit error message. The D15 LEDs fit fine and I have had no problems. They are slightly longer in length than the original bulbs (see picture above in my post) but are not touching the backup lens or housing and since they are so much lower in power and therefore heat generation I really see no problem using them. I really like the lighting effect that they offer and they are also not polarity sensitive.
