I was lucky enough to get one of the new skid plates from the fine folks at JSportUSA for my Touring model and I took some photos of the install process.
All of the hardware you'll need is included along with the requisite sticker.
To get enough room to install the plate, I drove up on the curb at the edge of my driveway. Certainly a jack and jack stands would be the advisable way to go, but this got it done.
Installation requires that you remove four small bolts at the rear of the front bumper fascia...
... and two larger bolts just behind the front suspension.
Lift the plate in place (it's light enough to support with one hand) and replace the factory hardware with the bolts provided.
That's it. You're done.
The plate does have a cutout for the oil drain plug.
I'm very happy with the fit and finish of the part and it does give me added confidence that I'm not going to empty the contents of my oil pan on a rock when out on the trail. I appreciate that it is extremely light weight and that there is very little loss of clearance with it installed.
Cost: $395.00 USD including CA sales tax
Install Time: 20 minutes.
Tools Needed:
- ratchet with assortment of metric sockets
- allen wrench
- curb to drive up on
- sheet of cardboard because I like these pants
The skid plate is a single piece of what I think to be 1/8" thick aluminum plate that has been powder coated black. It's well protected and looks great out of the packaging.All of the hardware you'll need is included along with the requisite sticker.
