1 - 4 of 4 Posts
I have been using a portable Garmin GPS unit and have many saved places and addresses from my travels. I would like to import these into the Passport (Garmin) navigation system. I was able to export them to a USB stick successfully, and then plugged the USB stick into the Passport but I can't figure out how to import the data. Any ideas?
Edit: I should add that some of these saved places are off-road waypoints that are not easy to enter manually, so I would like to be able to transfer them.
Discussion Starter · #2 ·
One option is to continue to use the dedicated GPS unit, but I lose the integration with the rest of the infotainment system, have another wire (power) to deal with, etc. Doable, but not as elegant.
How about save the garmin to drive to those spots then enter them into the Honda. Just an idea
If I don't find a way to transfer the data, that is what I will probably do ... In the end, not a big deal.
1 - 4 of 4 Posts
