1 - 12 of 12 Posts
I am new to Honda ownership in the last month and a half. I have a 2022 Honda Passport Trailsport. I have noticed several times now I get this message regarding the idle stop. "Idle Stop Temporarily Interrupted: System Warming Up or Charging" there is an image of the idle start logo with a line thru it along with a battery symbol next to it. Has anyone seen this or know what it means? I have looked abut haven't seen anyone mention this directly. Is it safe to drive my car? The dealership cannot get me in for another 3 weeks.
2021 Passport Elite
Read the manual, you get that message sometimes when the A/C or heat in on.
FYI, order the full manual from Honda, the one the dealership puts in the glove box is missing a lot on information. You can also download the full manual if you prefer. It free
It's not a "problem" for the reasons discussed here. If you're in the snow belt, as temperatures are falling, the more often that message is liable to pop up.
Thank you for taking the time. But temperatures were in the 70s, and all conditions met for it to work as per manual. I even took the car for a 30 min drive yet still the same msg(chargeing system). 🙄
I checked the battery and charging system voltage of the car and both were good.
Ill try to connect my obd and check what is giving a signal for the idle stop system not to engage.
Thank you for taking the time. But temperatures were in the 70s, and all conditions met for it to work as per manual. I even took the car for a 30 min drive yet still the same msg(chargeing system). 🙄 I checked the battery and charging system voltage of the car and both were good. Ill try to connect my obd and check what is giving a signal for the idle stop system not to engage.
Same problem with our ‘22 Passport. Did you ever figure out what the problem was?
I believe its a glitch or something of that sort. In the odessey forums one guy offered a solution and it actually worked for my 22 PP. However, it occured one time again and i wish i know what triggers it.
Font Screenshot Parallel Communication Device Number
I hope it helps 🙏. (If it did help credit goes to that person in the odessey forums)
1 - 12 of 12 Posts
