You should be fine to update, idlestopper shouldn't cause any issues due to it just emulating a button press. I am gonna do mine next week sometime and I have idlestopper. I'll let you know if I brick it or not lol.
Please do! I appreciate itYou should be fine to update, idlestopper shouldn't cause any issues due to it just emulating a button press. I am gonna do mine next week sometime and I have idlestopper. I'll let you know if I brick it or not lol.
Updated today, no issues. My advice is don't even mention it to the dealership for the recall. They won't notice.Please do! I appreciate it
Does the update make it so you don't need the Idlestopper? Or is it something else all togetherUpdated today, no issues. My advice is don't even mention it to the dealership for the recall. They won't notice.
No you still need it, no idea what it actually changes. Honda don't give us patch notes lol.Does the update make it so you don't need the Idlestopper? Or is it something else all together
Its a recall. How Honda labels their TSBs is confusing compared to an actual recall. If you do a VIN inquiry (through the Honda dealership network) it comes up as an open campaign, which is a recall.I believe the update alters when the idle stop activates, not allowing it to idle stop the vehicle if the battery level is below a level that may not allow it to re-start. By the way, it is NOT a recall. It's a service bulletin.
Here's what Honda has to say about the difference.Its a recall. How Honda labels their TSBs is confusing compared to an actual recall. If you do a VIN inquiry (through the Honda dealership network) it comes up as an open campaign, which is a recall.
I have a hunch that Honda is just playing around with semantics on the Recall/TSB/"Service Campaign" issue. It's also interesting that the explanation at this link says TSB repairs are not safety related so cannot be described as a recall, but the Hood Latch repair for the 2019 Passport and the present Idle Stop system update are safety issues, non optional and they require the vehicle being returned to the dealer so qualify to be described as recalls despite the fact that Honda only issued TSBs. Passenger safety is certainly at stake if the hood flies open at highway speeds due to striker manufacturing defect or if your car shuts down and fails to restart in the middle of traffic and you are forced to exit the car to seek safety on the road side.Here's what Honda has to say about the difference.
HONDA Technical Service Bulletins (TSBs) - Honda-Tech - Honda Forum Discussion
Thats not an actual Honda statement.Here's what Honda has to say about the difference.
Its kinda confusing for techs too. On the service info search it will show recalls first thing regardless if you search something unrelated. The recalls are yellow icons, which also shares a similar color with service news, and repair procedures. Service bulletins are a unique orange color. Just reading the bulletin you wouldn't be able to tell if it was a recall or not without those icons.I have a hunch that Honda is just playing around with semantics on the Recall/TSB/"Service Campaign" issue. It's also interesting that the explanation at this link says TSB repairs are not safety related so cannot be described as a recall, but the Hood Latch repair for the 2019 Passport and the present Idle Stop system update are safety issues, non optional and they require the vehicle being returned to the dealer so qualify to be described as recalls despite the fact that Honda only issued TSBs. Passenger safety is certainly at stake if the hood flies open at highway speed due to striker manufacturing defect or if your car shuts down and fails to restart in the middle of traffic and you are forced to exit the car to seek safety on the road side.
Before Honda made it's seemingly reluctant move to update the Idle Stop system after receiving complaints since 2016 from Honda Pilots owners, it ignored a class action lawsuit about the Idle Stop system and waited until NHTSA launched an investigation in 2022. That NHTSA investigation was launched as a safety investigation but Honda didn't wait for the results of the investigation, it deftly preempted whatever the conclusions of the NHTSA might arrive at the and rectification suggested and by issuing a TSB.
Apparently recalls gets loads of bad press but TSBs sounds innocuous in headline news, it could be the name of a new car made by Honda so the press will just ignore.
I use a NOCO 5 amp. However getting to the battery in the Passport is a royal PITA. The positive side is ok but negative is the problem. Instead I ground the charger to a bolt that I put in the vehicle for just that purpose. NOCO instructions say that the charger must be grounded to the negative post of the battery -- to me, after several searches and talking with many people, negative is a negative, and the 5 amp is a really safe power supply to work with. I bought my Passport less than two weeks ago and have put the charger on 2 times just for the heck of it and it works great. As a second thought if you buy the charger from Battery Tender their instructions are to ground to the vehicle -- I find this interesting and wonder why NOCO is different.Side question...I do mostly short trips, and have had to replace my battery recently, what do you use or suggest for a trickle charger?
You might have something there. Yet I believe that Honda is not the only manufacturer to play this card....I have a hunch that Honda is just playing around with semantics on the Recall/TSB/"Service Campaign" issue.
I believe it's due to the Battery Tender not having a desulfation mode. I still run my Tender brand maintainers directly to the battery. My NOCO is directly connected as well.As a second thought if you buy the charger from Battery Tender their instructions are to ground to the vehicle -- I find this interesting and wonder why NOCO is different.
