I just installed all 3 No-Lo Skid Plates
4117 Views 6 Replies 4 Participants Last post by  ChucklesToy
10
I don't plan on doing any "rock crawling" with this Passport, but I do intend on taking it on some mild adventures. I figured I'd spend $800 ($1000 with powder coating) on underbody protection instead of potentially a lot more on repairs. The No-Lo Design plates are made from 3/16 bare aluminum making them very light.
10218
Front plate 17lbs
10228
Front plate installed to protect engine & transfer case (sorry I forgot a "before" picture)
10220
Gas tank skid plate 12lbs
10223
Gas tank before
10222
Gas tank with skid plate
10227
Differential skid plate 6lbs
10229
Differential before
10224
Differential with skid plate
10226
Diff & Gas tank plates
10225
Reactions: 5
1 - 7 of 7 Posts
*Note - I had to use my impact drill to break loose 4 bolts; the 2 sub frame stiffener bracket bolts at the rear of the front plate, and the 2 differential carrier bolts. The plates came with detailed instructions and the install was a breeze.
Reactions: 2
Nicely done! I might be considering these in the future. The one thing I'm in the market for now is a good bottle jack. Are you using a Powerbuilt jack? Your pics don't show the front of the jack, that's why I ask. And if you don't mind me asking which model because it looks like you have plenty of lift range. Thanks.
10230
Lift range 11"-22"
Reactions: 3
Much appreciated.
Nice setup! I'm hoping I win the NO-LO raffle for the gas tank skid plate. :)
3
Installed the No-Lo front and back today. Ordered them unpainted and cut out the jack point opening on the front. Pretty easy with their online instructions. Had the Burkman painted Steele version on my Ridgeline; like this aluminum version better. And fished my black updates with black lug nuts. Did the black tailgate letters a few weeks ago.
10319
10320
10321
Reactions: 2
1 - 7 of 7 Posts
