21 - 23 of 23 Posts
Read Only
Funny, I too have a home link issue, but only when I am backing out of the garage and only when I am close. I have to hit the button right when I clear the garage door, or when I get to the street. In between it doesn't like to connect. When I and coming home I can open the garage door from nearly a block away.
I wonder if the fact that I have a garage door opener with the rolling codes could be part of the issue. I may blow it out and reset it again and see if that helps.
Read Only
Just found this. Long post but it may help someone. I am going to give it a try tomorrow to see if it improves my systems operations.
I am posting this in case others have issues like I did. My RDX's Homelink buttons hadn't been working with my Chamberlain Liftmaster garage door opener for a year. I finally spent an hour today researching online then talking to Homelink and got it figured out. Homelink has great customer service. So if my steps here do not work for you, just give them a call.
Follow these instructions first to program RDX Homelink with a Chamberlain, extracted directly from Homelink's website HomeLink:
  1. For first time training, press and hold the two outer HomeLink® buttons, releasing only when the HomeLink indicator light begins to flash after 20 seconds. (Do not perform this step when training the additional HomeLink buttons.)
  2. Position the hand-held transmitter 1-3 inches away from the HomeLink surface (usually located on your visor, overhead console, or mirror), keeping the HomeLink indicator light in view.
  3. Using both hands, simultaneously press and hold both the desired HomeLink button and hand held transmitter button. DO NOT release until the HomeLink indicator light flashes slowly and then rapidly. When the indicator light flashes rapidly, both buttons may be released. (The rapid flashing indicates successful training.)
  4. Press and hold the trained HomeLink button and observe the indicator light.
    • If the indicator light is solid/continuous, training is complete and your device should activate when the HomeLink button is pressed and released.
    • If the indicator light blinks rapidly for 2 seconds and then turns a solid/continuous light, proceed with the following training instructions for a rolling code device. A second person may make the following steps quicker and easier. Please use a ladder or other device. Do not stand on your vehicle to perform the next steps.
  5. At the receiver (motor head unit), locate the “learn” or “smart” button (usually near where the hanging antenna wire is attached to the unit). If there is difficulty locating the training button, reference the device owner’s manual.
  6. Press and release the “learn” or “smart” button (the name and color of the button may vary by manufacturer).
    NOTE: Once the button is pressed, there are 30 seconds in which to initiate the next step.
  7. Return to the vehicle and firmly press and hold the trained HomeLink button for two seconds and release. Repeat the “press/hold/release” sequence up to 3 times to complete the training process.
    Retain the original hand-held transmitter of the RF device you are programming for use in other vehicles, as well as for future HomeLink programming. It is also suggested that upon the sale of the vehicle, the programmed HomeLink buttons be erased for security purposes. To erase the programmed buttons, perform the procedure shown in step number 1.
After completing these steps multiple times, I still couldn't get Homelink to work. So I called Homelink and they had me do a factory reset: Press all 3 Homelink buttons until the LED flashes rapidly and then turns off, this took around 30 seconds.
Afterward, we redid all the above steps. After programming, he had me press the Homelink buttons. The Homelink button I was programming was flashing rapidly for a few seconds before turning off, meaning it was talking to the garage door opening. The other 2 buttons were just slowly flashing, meaning they were not programmed. Then he had me check if the garage door Learn button LED flashes as well. (Best if you can have another person looking at the Learn button while you push the Homelink button.) I was by myself, so I pressed the Homelink button, then ran inside quickly and did see the Learn Button LED flashed several times before going off. Flashing meant it was also receiving a signal from the Homelink button. This showed the Homelink button and the garage door opening were communicating.
He then asked me if I had LED light bulbs in the garage. Indeed I had replaced them a year ago. (BINGO!) Turned out LED light bulbs use frequencies that sometimes interfere with the Homelink buttons. We have a Lexus with Homelink which worked fine, but somehow they interfere with the RDX's. When I untwisted the bulbs, the Homelink button worked immediately.
So if your Homelink button doesn't work or work intermittently, see if you have LED bulbs or other electronics nearby that are interfering. This would save you tons of time and frustration.
I guess we are all working with all sorts of variables. I have LED backup lights and LEDs in my two 10 year old Chamberlain openers and they both work fine. Go figure!
21 - 23 of 23 Posts
