I have EXL which came without rear gate kick sensor (normal config for EXL).
Does anyone know if installing kick sensor is a possibility ?
Based on what your needs for the hitch are the trans cooler would be the last thing to get. And as pshadoa stated the strange noise on the 7-8 shift. I think the wiring harness would be more beneficial with regards to versatility with the hitch. It's really not that difficult to install, just got done with installing it last weekend.thanks for the advise. I am not sure about trans cooler at this point. In short term, all I need the hitch is for bike and cargo carrier, so I am OK without it.
You sound confident with the hitch install and with that being said, personally don't think you would have any problems with the wiring harness! I also installed the adapter for the kick sensor and have had zero issues with it's operation. Works just as dependable as the original.How bad was the harness install? From the few videos I have seen, hitch itself is not too bad ...I keep reading about kick sensor issues with hitch ...anyway it is 25 degrees here and it will need to wait few months more ...
